Old 01-05-2018, 01:32 PM   #1
(propane) gas change over
Rather chilly here last night (17) at 2 the furnace stopped blowing broke out the electric heater. Pulled the tanks this morning the drivers side was still filled all the way the passenger side was empty I was told that there was an automatic change over when on tanked emptied what am I doing wrong?? Thanks
Frank and Janet Henn
Brandon Ms
2017 Crusader 380MBH
pushing a 2007 Dodge
fhenn is offline   Reply With Quote
Old 01-05-2018, 01:40 PM   #2
cavie's Avatar
Automatic change over doesn't make sense. You would never know one or the other was empty. You would wake up one morning with no gas. If there was one I would disconnect it. I like having some responsibility for myself.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-05-2018, 01:42 PM   #3
Head Rambler
Which way was the pointer on the changeover regulator pointed?
Were the valves open on both cylinders?
Gotta go campin!
Old 01-05-2018, 01:45 PM   #4
can not find a change over valve not any where near our last rv. I like the responsibility also when I change ot over went and refilled the empty tank asasp. where would this pointer be
Brandon Ms
Old 01-05-2018, 01:45 PM   #5
wmtire's Avatar
This is a FAQ, and we have a tutorial on it at this link. Let me know if you have more questions.
Propane automatic changeover regulator
2011 Flagstaff 831 RLBSS
Did you know that thousands of scientists from around the world are looking for a cure for my narcissism?
Old 01-05-2018, 01:56 PM   #6
Found it thanks like the top one hard too see with the black back ground.
Brandon Ms
Old 01-05-2018, 02:08 PM   #7
Cavie, you need to read up on how auto change over valves operate.
Almost all trailers/5th wheels have them and they absolutely do alert you when one tank is empty, as long as you understand what you are looking at.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 01-05-2018, 02:17 PM   #8
cavie's Avatar
What I do understand is not all trailers/5th wheels have such devices as mine is 15 years old and such things were not installed. Being an electrician for 45 years I also know that such things do malfunction. I also know that a newbie may not know what he is looking at. I prefer a manual change over so I know what is going on and not having to guess.
Old 01-05-2018, 02:20 PM   #9
Mine (2015 Wildcat 295ESX) has the auto change over as well, it doesn't work all the time, sometimes I have to go out flip it over and then back to get it to change tanks.
wildcatter is offline   Reply With Quote
Old 01-05-2018, 02:21 PM   #10
wmtire's Avatar
Excellent, so you are good to go now?
Old 01-05-2018, 03:06 PM   #11
Yes maybe we can stay warm with all of this Yankee weather.
Brandon Ms
Old 01-05-2018, 03:21 PM   #12
ben31's Avatar
Thanks for the link. I had never wanted to depend on the auto-changeover. However, this being a crazy cold winter, I didn't want the heater going out, so decided to use it. I still check the levels periodically, and keep an eye on the change-over valve (to check indicator color). It has changed over twice. I had expected it to and was ready to refill the empty tank as soon as it did. I am beginning to trust it a bit more with use.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 01-05-2018, 05:00 PM   #13
Don't be afraid of using the change over.
As long as you regularly take a look at the visual indicator (as intended) it will alert you when one tank empties and it switches to the full one. You will never have to go out in the rain or the cold in the middle of the night to manually switch tanks. I've been using auto switch over valves this way for the better part of 30 years when we got our first R/V that had dual tanks, with zero issues.
If you decide to ignore what it is telling you (indicating) all bets are off.
Old 01-06-2018, 02:03 PM   #14
When the flag goes red, I immediately turn the knob to the other side and pull the empty tank.
RussPastuch is offline   Reply With Quote
Old 01-06-2018, 06:28 PM   #15
My trailer came with documentation explaining the auto crossover valve, only to find it did not have one. Perhaps switched out by the dealer before I got it. But that is ok with me. I had one on another trailer but didn't like it. Crossover indicator was difficult to see, and confusing. Tank levels difficult to gauge, plus I didn't like the idea a gas leak could drain both tanks before I became aware. I have an automatic but made a personal choice to stay with the manual crossover.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
gas, propane
