Old 09-06-2017, 12:50 PM   #1
Clif's Avatar
Propane regulator on the slave side
My propane regulator on the secondary side started leaking and I want to replace but cannot find any specs for the regulator I believe it is a 30 psi regulator which flows across to the main regulator but would like to be sure. This is not specified in any of repair or data manuals
clif
2013 Crusader 295rst
2013 F250 Lariat
Clif is offline   Reply With Quote
Old 09-06-2017, 01:02 PM   #2
Probably a Fairview GR-630B
Here's one on eBay...
Fairview RV Regulator
Here's the Marshall version...
Marshall RV Regulator MEGR-630B-A
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-06-2017, 05:57 PM   #3
Clif's Avatar
Thanks I have the Marshall MEGR 130-30 which as near as I can tell superseded the 630B.
clif
2013 F250 Lariat
Old 09-10-2017, 07:15 AM   #4
Fred H.'s Avatar
I've had to replace mine twice now. Both lasting only one year. What could be causing these regulators to fail so often?
I'm seriously thinking of eliminating it when and if the last one I installed fails.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 09-10-2017, 08:34 AM   #5
Like everything else, they are made cheap. A fairly new (8 years or so) safety requirement for crossover lines exceeding so many feet. I got rid of mine years ago. Also got rid of the check valve fittings in the pigtails from tank to regulator that constantly fail. Replaced with straight through fittings. Been happy and problem free ever since.
Old 09-11-2017, 12:11 PM   #6
I bought this one. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 09-12-2017, 08:41 AM   #7
Mine did the same thing this summer purchased two of them so I can have an extra one, installed it with the yellow propane tape all is well. Its a simple remove & replace= do it your selfer.
esmoglo is offline   Reply With Quote
Old 09-12-2017, 11:50 AM   #8
Fred H.'s Avatar
Thanks for reminding me about those pesky check valves. I will also get rid of those check valves as I've had problems with those also.
Fred n Wilma
propane
