Old 09-05-2017, 09:58 PM   #1
calgarycampers's Avatar
PT 330RST Dump Valves
I have a black tank and two grey tanks according to the TT specs.
I can only find one grey dump valve and it is beside the black tank dump.
I crawled all over the trailer. Is there a second grey valve and if so, where?
The dealer has given me two answers but has not shown me the extra valve if it exists. Does anyone have a picture?
calgarycampers is offline   Reply With Quote
Old 09-05-2017, 10:02 PM   #2
Webfoot0807's Avatar
Are you sure you are supposed to have two? We have two gray tanks but they both empty from just one dump valve
Webfoot0807 is offline   Reply With Quote
Old 09-05-2017, 10:59 PM   #3
My thought is that there is just the one. My galley tank keeps saying it is over 2/3 full. I have never trusted gauges but this is chewing on me. I may rub a scope down to see if it full or not.
Thanks for the note!
Old 09-06-2017, 09:13 AM   #4
rocksolid's Avatar
Check underneath by the front tire on the drivers side. On my Crusader 297 RSK it is night up behind the skirting. It took me a while to find mine the first time too. Hope this helps.
rocksolid is offline   Reply With Quote
Old 09-06-2017, 01:44 PM   #5
I will check this weekend
Old 09-11-2017, 11:10 AM   #6
UPDATE I very carefully inspected the whole system and the 2017 only has one gate for the gray. I may change that.
Old 09-15-2017, 09:03 PM   #7
I just got the official word from Prime Time.
Your gray tanks are plumbed to drain with the same valve. You will have one that is for the 2 gray tanks and 1 for the black tank.
I may change that but it is nice right now. I will need to think about this.
Old 10-18-2017, 05:49 PM   #8
I have the same unit and the dealer never told me about that one. I was very perplexed when I shut what I thought was the only gray valve and still found water running out of my dump valve. Luckily I had a repairman coming out for a couple of issues who enlighten me. I thought I had a broken gate valve when actually problem was I just had a valve I didn't know about that was open
5ERSTEVE is offline   Reply With Quote
valve
