Old 03-02-2012, 09:31 PM   #1
jtad's Avatar
Question about a 2nd A/C
Some of you folks might know this or maybe RV Guy will chime in. I know my 298 BHD is 30 AMP, so i am pretty sure there isn't a wire already run to my vent in the bedroom like on a 50 AMP would have. But is the vent opening sturdy enough in the bedroom for a A/C, or do I need to beef it up? And how big of a pain is it to get the ceiling down to get the wire run over to the closet? Or is there enough room in the ceiling area to fish the wire over without taking the ceiling down? I am sure someone on here has added a second A/C to their 30 AMP Crusader.
2011 Cursader 298 BHD
2012 F-250 FX4 6.7 Power Stroke
B&W Companion Hitch
Days Reserved for 2012: 39
jtad is offline   Reply With Quote
Old 03-02-2012, 09:48 PM   #2
Was wondering about this for our Crusader 260RLD. We did camp last year in 107 degree heat but stayed nice and cool inside it so maybe i'm just being a nervous Nellie.
imabmwnut is offline   Reply With Quote
Old 03-02-2012, 09:50 PM   #3
jtad's Avatar
Once it cools down it does a fine job, but Texas in the summer is tuff !
B&W Companion Hitch
Old 03-03-2012, 07:11 AM   #4
M109Rrider's Avatar
Could have sworn RV Guy said all Crusaders were 50 amp in a thread a while back... maybe I mis read it.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 03-03-2012, 07:16 AM   #5
M109Rrider's Avatar
Nevermind, found the thread. He was referring to the 320.
Jason and Billie
Old 03-03-2012, 09:55 AM   #6
If all you have is a 30 amp plug, you are going to bite off more than you can chew by trying to add an AC. One part is the wiring, all the way back to the breaker panel for the AC. Next is rewire the 30 amp from the outside connection, to the breaker panel, with 50 amp service. Then you will also have to change your converter and breaker panel.
As for the vent, you can pull the inside cover and see if the vent is boxed in. If it is, it should hold the AC. If not, will need to remove the ceiling, and box in the vent opening. Sounds a like a lot of work, and $$$$, and probably is, to both.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 03-03-2012, 09:59 AM   #7
Commercial Member
JTAD - The roof vent is definitely strong enough for a 2nd A/C but "upgrading" a 30 AMP unit that was not wired for a 2nd A/C is quite a job for sure. Not saying it can't be done, but won't be easy. I THINK what might be common for after-market A/C upgrades is to install a 2nd A/C and have a dedicated line for the A/C that is wired to an exterior source where the customer would plug in a 2nd 110 power supply. I DON'T KNOW THAT FOR SURE BUT I THINK IT HAPPENS. CONSULT YOUR DEALER!!!!
RV Guy is offline   Reply With Quote
Old 03-03-2012, 06:54 PM   #8
jtad's Avatar
Yea RV Guy that is exactly what I am doing. I am running a dedicated 20 amp line. I have a marine grade male 20 amp plug to mount on the side of the coach near the 30 amp for shore power. That was the main thing I was wondering if that vent opening was strong enough or if I was going to have to do something with it. So that is good to know. Thanks RV Guy. I will keep everyone posted on that upgrade. Might be a month or so before I get to it.
B&W Companion Hitch
