Old 02-26-2012, 09:45 PM   #1
JoeyO's Avatar
Send a message via Yahoo to JoeyO
Question on stabilizing TT
Hello,
Just bought a pair of BAL Extended Fit X Chocks. Is it also wise to buy two pair of the yellow plastic block Chocks as well for quick stops on the road if necessary? I also found some high end aluminum Chocks with teeth on the front and back to grab into the road if necessary. But those were $30 ea. so ugh! Not certain if that is a good investment. Please let me know, I have a twin axle TT and want to know for a hasty stop, would the Yellow plastic Chocks do?
Thanks! joe
OTeam
2018 Genesis G80
2010 370z Convertible 6 Stick
2011 Expedition 5.4L 4x4 Limited
2018 Highland Ridge 275 Light
Semper Fi
JoeyO is offline   Reply With Quote
Old 02-26-2012, 09:54 PM   #2
b1b1das's Avatar
I have used the yellow plastic chocks, but if you have the X chocks, why not use them? Keep a cordless drill or impact handy with a socket... Just a thought..
b1b1das is offline   Reply With Quote
Old 02-26-2012, 09:55 PM   #3
jtstromsburg's Avatar
Yes, the cheapo plastic chocks are needed. Both for the quick stops and for security while leveling. You need to chock whole leveling but still allow the tires to adjust add you level. Hard to explain, but the basic chocks are definitely needed.
Joel
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 02-26-2012, 09:57 PM   #4
dilgerc's Avatar
Joe, I wouldn't think for a quick hasty type stop you would use anything cause you prob won't be disconnecting from your tow vehicle. At least I don't. I do use the x chock when I disconnect tho I have the yellow ones but don't ever use them. That's just me tho.
dilgerc is offline   Reply With Quote
Old 02-26-2012, 10:18 PM   #5
grhodes50's Avatar
You need the yellow ones when hooking/unhooking the tt and when leveling. When raising and lowering the tongue jack the tires need to be able to rotate. The movement is slight, but needed. The X-chocks will not allow this movement.
The X-chocks are to be installed after the tt is level..
Gary & Trish
2018 Nights Camped - 5
Old 02-26-2012, 11:12 PM   #6
Agreede with gr...I too have the xchocks...don't want to lock those in until you are all levels...the plastic ones are great for hooking up and unhooking
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 02-27-2012, 06:18 AM   #7
JoeyO's Avatar
Thanks everyone! I realize my question was not complete regarding hasty stops. But it's clear that they are needed and that is what I had to confirm.
OTeam
2018 Genesis G80
Semper Fi
Old 02-27-2012, 06:42 AM   #8
walterw11's Avatar
What will happen if you use the x-chocks from the beginning. Do the wheels move that much when you raise and lower you trailer. I've tried both ways and I don't notice a difference.
walterw11 is offline   Reply With Quote
Old 02-27-2012, 07:34 AM   #9
punkaccountant's Avatar
X2 I purchased the X Chocks in hopes of preventing some of the movement in the trailer, especially, at night. However, I have found little or no improvement when using them so I don't really use them that much. I find the cheapo chocks easier to use.
punkaccountant is offline   Reply With Quote
Old 02-27-2012, 07:18 PM   #10
b1b1das's Avatar
Really?
I sure wish I would have read this before I ordered my X chocks, two days ago...
2012 Stealth RG3210
2011 Dodge Ram 2500 Mega Cab Laramie 4x4
2010 Ford F150 Super Crew Lariat 4x4
