Old 03-06-2012, 11:33 AM   #1
JoeyO's Avatar
Send a message via Yahoo to JoeyO
Quick question on P2 Break Controllers
Hello!!
I installed my P2 brake controller yesterday, piece of cake with that plug and play harness. Anywho, everything snaped in like a dream, however, I noticed that as long as it is plugged in, the two blue LED likghts on the screen stay lit (power & boost). Is this an issue for the battery or normal?
Dose everyone remove thier break controllers or leave them stationed in thier trucks? You can't see it from the driver window, so its hidden, but just courious if its best to remove or leave it alone. I just want to make certain I'm not going to drain the battery by keeing it plugged in.
Thanks! Joe
OTeam
2018 Genesis G80
2010 370z Convertible 6 Stick
2011 Expedition 5.4L 4x4 Limited
2018 Highland Ridge 275 Light
Semper Fi
JoeyO is offline   Reply With Quote
Old 03-06-2012, 12:53 PM   #2
Joe
The lights will shut off after 15 min. of no activity. I installed the same controler and had the same question. I read through the operation manuel and found this out.
Mickey1 is offline   Reply With Quote
Old 03-06-2012, 03:01 PM   #3
Wanna Be Camper
SaskCampers's Avatar
I have had our P3 plugged in for 4 years now. Only issue is twice in that time I had to disconnect it and plug it back in as it locked up.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 03-06-2012, 08:51 PM   #4
JoeyO's Avatar
Thanks Guys! That helps!
OTeam
2018 Genesis G80
Semper Fi
