Old 06-07-2015, 06:24 PM   #11
We ended up finding a cross member to the rear of the jacks about 14" we then raised each and found our shortest, then we guestamated our furthers since we couldn't fully lower the jacks to find our our furthest measurement and we found a sweet spot at 18" inward of the outside frame rail.... now is that the best spot? Who knows, all I know it took out a substantial amount of the shake and we should be good for the years to come. I know I still have to relocate the batery box but that a project for future me to face as we will on a seasonal site for the remainder of this year.
ID:	79358   Click image for larger version
ID:	79359   Click image for larger version
ID:	79360   Click image for larger version
OnyxSky is offline   Reply With Quote
Old 06-07-2015, 09:54 PM   #12
Originally Posted by elind View Post
I put the rear arms to the center at first (pic) and it didn't have enough clearance to the weak cross member.
Thank you. No need for me to figure out what you have already done.
I just have to wait for the Big Brown Truck (UPS) to deliver them so I can get started
Jeff in NC is offline   Reply With Quote
Old 06-08-2015, 08:18 AM   #13
Phat Phrog Stunt Crew
elind's Avatar
Good luck and have fun.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 06-13-2015, 10:33 PM   #14
DONE... What a big difference. I wish I had done this earlier.
Now I am ready to go somewhere!!!
Old 06-16-2015, 10:37 AM   #15
Here are a few pics from my Wildcat. I put the rear arms to the center at first (pic) and it didn't have enough clearance to the weak cross member. So aimed them forward attached to the frame. I attached the front arms to predrilled holes on the floor of the front cabinet. Then I cut a inch off the floor behind the battery box and slide it back so the front arms would clear it. I them trimmed an inch or two off the spare tire mount again for the arm clearance. The third mod is to move the spare tire winch back 3" so you can carry your up front. Have fun.
Elind. I am planning on mounting my rear the same as yours. I have the same telesoping rear jacks. Could you tell me how far forwards from the jack you mounted the strong arm?
2015 Chaparral 360IBL 50th anniversary edition.
sau4u is offline   Reply With Quote
Old 06-16-2015, 07:15 PM   #16
elind's Avatar
I think I attached the arm to the rear stab pad with it in the raised position. Then I locked the arm with the T handle to have a few inches extended out. Installed the mounting bracket to the other end and swung it up to the frame to mark the holes for drilling. It's about 30" from the center of the stabilizer to the center of mount hole.
2014 Wildcat 327ck
Old 06-16-2015, 07:29 PM   #17
After the arm is attached. Will your rear telescoping jack go up ask the way. In your pic yours looks the same as mine. But I dont think mine will go up all the way with the arm installed.
Old 06-16-2015, 08:50 PM   #18
elind's Avatar
At 30" from the stab center to the front mount on the arm the electric stabilizer comes all the up on my Wildcat. When I put the arms toward the center the stabilizer didn't come all the way up without an adapter kit. Lippert also says you need a 3X3 angle iron cross member to hold the two arms.
2014 Wildcat 327ck
Old 06-16-2015, 09:05 PM   #19
I installed mine as you have described. Towards the front. 30". Away from center of stabilizer. It will up almost all the way. Maybe 1/2 shy. I may put my own bracket in to drop the pad a touch. Otherwise fit perfectly. I cannot believe how much of a difference. For me as per instruction. I levelled trailer. Dropped the front 1". Put rears down and locked in place. Picked up front 1". Locked in place. Bumped up. Is that how you have been doing yours. Any other suggestions.
Old 06-16-2015, 09:29 PM   #20
elind's Avatar
I do the same!!! If you want a little more put jack stands near the axles to take the center bounce from the long frame.
2014 Wildcat 327ck
