Old 05-31-2011, 08:00 PM   #1
Remove cover to inverter/circuit breaker
Before I break something...How do you remove the cover to the inverter/breaker box? Does it pull off? I do not see any screws..
Edit..it is a converter not inverter
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 05-31-2011, 08:54 PM   #2
We have a 320 Crusader and there are 4 screws on the outside and then one on the inside where you open the door.
Brian, Kellie, Breanna & Alyssa
2011 Crusader 320RLT
BC11 is offline   Reply With Quote
Old 06-02-2011, 04:35 PM   #3
I do not see any screws on mine
Old 06-02-2011, 05:45 PM   #4
Notuck's Avatar
Are you trying to remove the entire cover or just open the access door to the fuses and breakers? If trying to just open the door push in and it should click and pop out to pull open.
Notuck is offline   Reply With Quote
Old 06-02-2011, 07:44 PM   #5
Herk7769's Avatar
Yep, just push the center of the panel at the top. It should go in; then pop right open.
HAM CALLSIGN - KC3FFW
Old 06-03-2011, 12:27 PM   #6
Duh
Yep, next time I will try to fix something in decent light....Boy push on the triangle it comes right open....I definately won the dumby award for this one....thanks everyone.
Old 06-03-2011, 02:32 PM   #7
janegraves's Avatar
don't feel bad, I forced mine and broke it. mine is now held up with scotch tape.
Jane
First RV was a 1968 Nimrod popup
Second RV is a 2012 Sunseeker 2300
nights camped 2011: 42
nights camped 2012: 48
nights camped 2013: 40
janegraves is offline   Reply With Quote
breaker
