Old 09-26-2019, 09:03 AM   #1
Removing Bounce and Wiggle
So this isn't just a Prime Time question. When we are set up and leveled, (have a 4 point Auto Leveling System on my Crusader), we still rock and roll when one person is walking around the trailer. I use a tripod on my hitch box and it helps, especially with the forward, and backwards, rocking.
My question is, what do you all use when you're parked for awhile to stabilize your rig.
My DW complains because I get up early and walk around getting dressed to take the dog out and making coffee. We will sit for a 2 month period so thought I'd try to improve the stability while parked. Any idee's?
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 09-26-2019, 09:12 AM   #2
I took 99.9% of all my 5th wheel movement out with the addition of JT Strongarms and X-Chocks.
I DO NOT have the level-up system but I have read several places where it can be used with adapter lugs.
See this web page at eTrailer.
Can JT Strongarms be used on Lippert Ground Control/Level Up
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-26-2019, 09:25 AM   #3
Justice12t's Avatar
I have the JT's and the 4 point auto level. Installed without issue and works very well. I also use x-chocks.
2016 Prime Time Crusader 294RLT
2018 RAM 2500 Laramie CTD, CC, 4x4...ect
2017 Days Camped - 14
2018 Days Camped - 15
2019 Days Camped - 34
Justice12t is offline   Reply With Quote
Old 09-26-2019, 09:25 AM   #4
frank4711's Avatar
I have these for front jacks https://www.amazon.com/Andersen-Hitc...NsaWNrPXRydWU= and this https://www.amazon.com/X-Chock-Wheel...s%2C166&sr=8-2
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 32 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 09-26-2019, 09:31 AM   #5
Canadian Member
Try the X-Chocks first. You can make them using stainless steel hardware and pressure treated 4x4 if you prefer.
Then, if the X-Chocks arenít sufficient you can use either the JT Strongarms or SteadyFast system.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 09-26-2019, 09:39 AM   #6
I use this style of wheel chock. Do you think the X chock would be a better use for my situation?
2003 Duramax
2017 Crusader 315
Old 09-26-2019, 09:48 AM   #7
Fulltime family RVer
Here are a couple of articles:
https://learntorv.com/shake-shake-sh...stabilization/
The JT StrongArms are a great product but the SteadyFast system is better. Same performance, less bars, and easier on the hands.
https://learntorv.com/product-review...t-stabilizers/
Old 09-26-2019, 09:52 AM   #8
anyone installed the steadyfast system on a rig with a front mounted spare? I emailed the mfr. and asked for suggestions, one to NOT relocate the spare. I wonder if the side/side arm can be mounted in the rear?
nayther is offline   Reply With Quote
Old 09-26-2019, 10:02 AM   #9
There have been HUGE debates here on the merits of X-Chocks being used as wheel chocks. There is LOTS of reading/opinion if you care to do a search.
I've read claims of some saying the manufacturer of X-Chocks say they are not to be used in place of wedge type wheel chocks so I won't recommend you abandon the wheel chocks you have.
I will recommend if you install the X-Chocks correctly and tighten them down it WILL eliminate wheel movement. I can slide the wheels/tires on my ring when they are installed and they don't budge. (not that I make a habit of that!)
The X-Chocks are the first thing to go on when parked and the last to come off.
Old 09-26-2019, 10:23 AM   #10
Retired JSO's Avatar
The only way to remove almost all bounce it to take the weight off the springs and tires. Without completely jacking the tires off the ground, the supports/strong arms stabilizers can only reduce some movement. I reduced a considerable amount of movement by installing a pair of scissors jacks extremely close to the trailers tires. We now have a trailer with a 6 point level system. It works great on cement but needs resetting on gravel and sand after a few days.
Retired JSO is offline   Reply With Quote
Old 09-26-2019, 11:06 AM   #11
Canadian Member
X-Chocks will prevent the tires from rotating. As long as there is weight on the tires they will do what they are supposed to do but my auto-level system occasionally lifts the tires off the ground on one side. The JT Strongarms and SteadyFast systems are designed to prevent any wiggle but they are more expensive and require you to drill holes in the frame for installation.
Old 09-26-2019, 12:33 PM   #12
frank4711's Avatar
The leveling system does take some weight off tires when it levels .... I am good with the lack of movement I get with Andersen blocks on the front jacks and the x-chocks .... If you do not have auto-level the JT Strongarms and SteadyFast systems would seem to be best solution ... I can not see adding jacks not attached to the camper as a good solution .... Thanks Frank
Old 09-26-2019, 12:44 PM   #13
X-Chocks and Steadyfast eliminates just about all wiggle in my trailer.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 09-26-2019, 12:59 PM   #14
heavynlori's Avatar
We have on our Crusader:
4 pt auto level
Tripod hitch support
Steadyfast system
Valterra jack under back frame
Two old slideout jacks in front of tires (leftovers and work well for this purpose)
No x-chocks....gave to neighbor parked on gravel site
We are parked seasonal on a full concrete pad with wooden steps instead of trailer steps
We are rock solid compared to old gravel site using the exact same setup - must be the concrete pad this year !
heavynlori is offline   Reply With Quote
Old 09-26-2019, 01:01 PM   #15
frank4711's Avatar
4 pt auto level
Steadyfast system
Two old slideout jacks in front of tires (leftovers and work well for this purose)
Yep that'll do it
Old 09-26-2019, 01:28 PM   #16
RollnStone's Avatar
I have a MicroLite 25KS. This was a simple solution that I found. It's not elegant, but it works. Also, I cut the top angles parallel to the bottom.
Wobble Stopper | Trailer Life
RollnStone is offline   Reply With Quote
Old 09-26-2019, 02:07 PM   #17
A good bra seems to help
Gmar60 is offline   Reply With Quote
Old 09-26-2019, 02:13 PM   #18
BINGO !!
Chocks...Xchocks will do nothing for Bounce and wiggle. You nailed it. Got to have support underneath to settle the bounce on the leafs or springs.
TheWolfPaq82 is offline   Reply With Quote
Old 09-26-2019, 03:08 PM   #19
Have a motorhome, same thing. I eliminated a great deal of the movement by putting blocks under the leveling jacks so as the jacks don't travel very far.
A trailer parked next to us used blocks under his leveling jacks and he explained to me it took just about all the movement away.
The more leveling jacks are extended the more movement in my experiences.
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
Old 09-26-2019, 05:52 PM   #20
New to FR. Old to TT
We have found a lot of excessive movement can be stopped by using blocks under the level up pads to reduce the length of the shaft extended beyond the cylinder.
Tall frog is offline   Reply With Quote
