Old 01-31-2014, 08:53 PM   #1
plshilo's Avatar
Replacing Kitchen Faucet 27.0RET
OK Guys,
Here is the question I want to replace the faucet in our kitchen (old one leaks). The problem is we have the old one still in and am thinking of changing from PEX to standard pipe and install 2 shutoff valves to go with the new faucet? So anyone done this before................Let me know as we are going forward tomorrow.
Phil & Linda
Phil & Linda and our two four legged babies - Cricket & Brutus
2016 F350 Super Duty
2017 Heartland Big Country 3560ss 5th Wheel
plshilo is offline   Reply With Quote
Old 01-31-2014, 10:35 PM   #2
Dave_Monica's Avatar
I've changed out a faucet set and should have done what you're suggesting as re-attaching the PEX lines to the new faucet was a nightmare!
If you're buying from Lowes, HD, they'll have everything that you'd need. Just tell the sales asst. that you're converting from 1/2" PEX to whatever comes with the new faucet...probably 1/4" braided line.
Dave
Old 01-31-2014, 10:42 PM   #3
plshilo's Avatar
Yes, that is the plan. It is 1/4" braided line, just plan to get the valves.....try to get it Not to Leak. Thanks
Phil
Old 01-31-2014, 10:52 PM   #4
Phil
So it sounds like all you need is a PEX to 1/4 NPT adapters and 1/4" ball valves paying attention that you got the male/female ends correct.
Dave
Old 01-31-2014, 11:04 PM   #5
plshilo's Avatar
Dave
what I plan is to use is valve with 1/4" NPT outlet so will connect right to faucet.
Old 02-01-2014, 07:19 PM   #6
plshilo's Avatar
OK,
Linda & I finished the Faucet Today. I have pictures and am going to put them and the whole story in Updates..................
Phil & Linda
Old 02-09-2014, 08:33 PM   #7
DS ADV Rider
OK Guys,
Phil & Linda
I was forced to change my broken faucet but wanted to swap to one with a pull-out spray. The new faucet plumbing didn't match the old one, so to avoid buying PEX tools I just bought two flexible braided M-F 24" hoses and connected them between the existing supply pipes and the new (and differently located) faucet connectors.
Worked quite good, and you can get those braided hoses c/w Shut-off valves.
Bob
Lacrosse 301RLS Touring Edition
GMC Sierra SLT 2500 4X4
BMW F650GS Dakar
Suzuki DR350SE & Suzuki DR650SE
Specialized FSR XC Comp
DualSport is offline   Reply With Quote
Old 02-09-2014, 10:12 PM   #8
2007 WildCat 32QBBS
18CrewDually's Avatar
Bob
X2. I did just the same. No problem, no leaks.
18CrewDually is offline   Reply With Quote
faucet
