Old 05-10-2014, 12:13 PM   #21
FOR irishrv...you say you have had your Crusader for 1 year, have you had any problems with.Im buying this camper 140 miles away am concerned I will be going back & forth.Or anyone who bought a Prime Time product,what problems did u have with it the 1st year if any.
ch6989 is offline   Reply With Quote
Old 05-10-2014, 01:48 PM   #22
irishrv's Avatar
1 leaking window. 1 leak from water pump (cross threaded). Darco fabric mentioned above. All fixed by dealer. I don't think any Rv is issue free. I used the first year to find any issues and get them repaired.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 05-10-2014, 02:22 PM   #23
That's what scares me my dealer is to far away.Bought my Keystone Alpine had no problems in the 1st year.Had a rear electric leveler motor go out the 2nd year,called lippert they send me a new one free, I installed it.Also had a storage door delaminate on the gel coat. Keystone send one to nearest dealer & paid them to install it & replace decal.Had another question for you irishrv how does the auto leveling work for you?
Old 05-10-2014, 03:38 PM   #24
irishrv's Avatar
Works great. You unhitch then bring the front down some. Pull the rear pins and hit auto level and move on. I think lippert is using a new setup that you don't need to pull rear pins but not sure if crusaders have them yet. Either way far easier than manual levelling.
09 GMC 2500HD D/A
Old 05-10-2014, 09:53 PM   #25
Picking it up on Friday,the furniture is supposed to be in on Monday.
Old 05-16-2014, 06:50 PM   #26
Picked up the camper today ,very unhappy with it pulled it 100 miles on interstate only getting between 8-9 Mpg about 65 miles per hr..Always got between 10- 11 on my keystone & it weighed 12,400 dry weight.What are you getting pulling yours?
Old 05-17-2014, 08:41 PM   #27
irishrv's Avatar
Don't know exact mpg. Seems pretty close to my previous cougar but since crusader is 2k heavier not quite as good but very close. Nothing shocking.
09 GMC 2500HD D/A
Old 05-18-2014, 07:08 AM   #28
OK, got stuck with the 15inch tires going to bite the bullet & buy 16" rims & tires.Hope to sell the 15" set.I am carrying the rv about 2" high in the front this will level it out, the 16" tires are about 3.8 inches taller which should give me about 2 inches higher in back.Hope this helps the mpg.Atleast ill even out the rev.per mile between the truck & camper, as it is the tires on the truck make 750 rev. per mile the camper wheels only do 650 rev. per mile.
Old 05-18-2014, 07:19 AM   #29
Ford Idaho's Avatar
Just be sure you have enough clearance between the top of the tire and the wheel well.
Old 05-18-2014, 02:33 PM   #30
opps said that wrong..the campers tires have to go 750 rev. per mile , while the truck tires only go 650 rev. per mile.
Old 05-18-2014, 11:06 PM   #31
Looks to have a lot of clearance.These 16" are a option on this camper.
