Old 11-23-2011, 03:17 PM   #11
Commercial Member
Use a 1" #8 screw - slide the bulb seal all the way up in the track so that it's snug against the horizontal bulb seal - push the bulb down just a little at the top to expose the backside of the inner part of the bulb and run the screw thru the backside of the bulb through the retainer and into the track. Don't overtighten as that's when the head often will pull thru the rubber. Nothing to seal after installing the screw as it's going thru two layers or rubber and putty under the extrusion.
Good luck and sorry for the inconvenience. Have a great holiday.
PTM
RV Guy is offline   Reply With Quote
Old 11-24-2011, 07:53 AM   #12
grhodes50's Avatar
I had that same problem at the front of my bedroom slide. I removed the seal, then kind of re-shaped it by squeezing the flat back side. Not enough to put a crease in it, but just a little bow. I reattached the seal and haven't had a problem with it since.
I guess the screw is a better idea.
Thanks for sharing the pic. Got anymore?
Gary & Trish
2018 Nights Camped - 5
Old 11-24-2011, 08:08 AM   #13
tbritt's Avatar
Got a few more Gary, will post some more soon....BTW Happy Thanksgiving to you and yours
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 11-25-2011, 03:59 PM   #14
tbritt's Avatar
southern most part
2012 GMC 2500 HD
2011: 365
2012: 365
Old 11-25-2011, 04:03 PM   #15
tbritt's Avatar
local wildlife......big a-- lizard!!!!
2012 GMC 2500 HD
2011: 365
2012: 365
Old 11-25-2011, 08:26 PM   #16
grhodes50's Avatar
Nice pics. Thanks!
Be caredul of all them wild critters down that way!
Gary & Trish
