Old 11-12-2011, 06:59 PM   #1
tbritt's Avatar
Road test 303RK
Hi guys & gals, we closed the park (Burnet Tx) that we were working at for the winter on the 31st of Oct. and have been on the road since. (Granbury Tx) for a few days, then to Thackerville Ok (Windstar) for a couple of days. Then on to "HOME" (Antlers Ok). Worked around the house for a few days and left for (Little Rock Ar) been here for a few days and pulling out tomorrow.....will let you know how things go and the next stop....only one issue so far galley tank valve wont close all the way. OBTW... headed to (Key West Fl) for the winter.
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 11-12-2011, 08:17 PM   #2
grhodes50's Avatar
Good luck on your trip and keep us posted on how things are going.
Let me know what you find out on the grey/galley tank valve. Mine has always seemed a little stiff, but has always worked.
Gary & Trish
2018 Nights Camped - 5
Old 11-16-2011, 05:55 PM   #3
tbritt's Avatar
Lake Okeechobee Fla, 17 days on the road all doing well @ 280 miles from Key West will let you know about the ride...
2012 GMC 2500 HD
2011: 365
2012: 365
Old 11-19-2011, 06:59 PM   #4
tbritt's Avatar
key west trip
2012 GMC 2500 HD
2011: 365
2012: 365
Old 11-19-2011, 07:06 PM   #5
tbritt's Avatar
had to add a few states
2012 GMC 2500 HD
2011: 365
2012: 365
Old 11-22-2011, 06:28 PM   #6
tbritt's Avatar
303 road trip
Trip was fine only two issues .....got a rattle in the A/C vents some were something broke loose....and the back rubber seal on the front slide just slid down on it's track.....what's with that????
2012 GMC 2500 HD
2011: 365
2012: 365
Old 11-23-2011, 11:55 AM   #7
Commercial Member
tbritt - there's a screw that holds the bulb seal in it's track at the top. My guess is the bulb seal pulled thru the head of the screw allowing it to slide down. If so, that's an easy fix - sorry for the inconvenience, though.
RV Guy is offline   Reply With Quote
Old 11-23-2011, 02:51 PM   #8
tbritt's Avatar
Thanks RV guy for getting back....long time no talk to, but no screw or hole where it may have pulled out...I did see the one at the end of the blub seal across the top. What size and type do I need to get?
2012 GMC 2500 HD
2011: 365
2012: 365
Old 11-23-2011, 02:55 PM   #9
Commercial Member
Well that might explain it - sorry for missing it. Before I go and do something crazy, is this for your little bedroom slide or the large living room slide? I want to make sure.
Old 11-23-2011, 03:09 PM   #10
tbritt's Avatar
The bedroom slide on the backside
2012 GMC 2500 HD
2011: 365
2012: 365
