Old 07-16-2012, 07:10 PM   #1
roll pin size
we went out with our 3150 tracer this weekend and the power stabalizer jack wouldn't work. I found out there was a roll pin that came out. It connects the motor to the gear rod. I installed a nail to get it to work, just wondered if someone knew the proper size pin to get to fix it correctly now that im home. Thanks.
2012 Prime Time Tracer 3150 bhd
troy berget is offline   Reply With Quote
Old 07-22-2012, 09:54 PM   #2
rracer5's Avatar
Wish I had my dial calipers with me.....I'd get under mine right now and check. If I get a chance, I'll grab them and check in the next few days.....unless someone chimes in first with the correct size.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-22-2012, 10:07 PM   #3
Dave_Monica's Avatar
You could check the hole size using drill bits. You'll want a split pin slightly larger than the drill size.
Dave
Old 07-22-2012, 10:11 PM   #4
Director, FROG
F.R.O.G.'s Avatar
Troy, call Sandie Dewalt, Manager of Parts at Prime Time, at (574) 862-3003. You should be able to get the information that you need.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 07-29-2012, 12:26 PM   #5
Thanks guys. I got it fixed up and ready to go out again next weekend. We have managed to get out about every 2 weeks sinse we got our Tracer and this is the only issue we've had. We are very pleased with the product. It is very nice to have this forum and everyone on it to help out when needed. Again thank you.
