Old 08-29-2017, 02:41 PM   #1
jcoff2003's Avatar
Roof Hole
I recently took a camping trip and had a branch puncture a penny sized hole in my rubber roof. The repair was slightly delayed, but the hole was covered with plastic during this time. However, when I climbed up to make the patch with repair tape it appears as though some water somewhere got under the rubber as there is a little bubbling about the size of a dollar bill or less. I applied the patch. Just asking opinions.....do I need to worry about the slight amount of water that made it in? Or do you think I'll be alright now that it's patched?
jcoff2003 is offline   Reply With Quote
Old 08-29-2017, 02:47 PM   #2
Semperfi24's Avatar
If it were me, the approach I would take would be to mark the area with a pencil (drawing a circle around the bubble). The circle will help you pin point after. I would then take a syringe and use that to suck all the water (or air?) out. Then seal the area that the syringe punctured (possibly several times depending on how much water/air is in the bubble.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
roo, roof
