Old 09-05-2014, 05:18 PM   #1
325RES2015
mrmoll1955's Avatar
Roof vent question
I own a 2015 crusader 325 res 5th wheel. Can the roof vent over the kitchen be swapped out for a good one with speed control fan and rain/temp sensor.
mrmoll1955 is offline   Reply With Quote
Old 09-05-2014, 05:24 PM   #2
Don't see why not if you can find power from a light or something.
Old 09-05-2014, 05:32 PM   #3
In the process of that install now. Fish a wire over to the kitchen light in the
ceiling or the bathroom fan. Installing a Fantastic Fan 6600R with an IR
remote. Don't foresee any problems.
grayfox is offline   Reply With Quote
Old 09-05-2014, 05:44 PM   #4
kenandterry's Avatar
I would suggest you remove the plastic trim on the inside ceiling around the factory vent. Sometimes the manufacturers have already left wiring in place for the very project you're mentioning (they did in our Georgetown)
Worth the look!!!!!!!
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-05-2014, 06:10 PM   #5
Planostu's Avatar
I put one on my 294 and like the comment above, I pulled a ceiling light and found several hot wires and spliced in there.
2015 Crusader 294RLT, 2014 Ram 2500
Planostu is offline   Reply With Quote
Old 09-05-2014, 06:19 PM   #6
Mine a 2014 Crusader, but no wires in the vent.
Old 09-05-2014, 08:09 PM   #7
Planostu's Avatar
You will have to fish a wire from the run going along the lights. Splice there and then fish it over to your vent. 20 minutes tops. To find a hot wire, I stuck a sewing needle in to the wire insulation and put my voltmeter on the needle to find an always hot to insure I was not tapping in to a switched hot.
2015 Crusader 294RLT, 2014 2500 Ram
Old 09-08-2014, 11:39 AM   #8
wicked1's Avatar
Planostu how do you like your 294 I am thinking of getting either that or 290 at one of the next shows if I can get a good trade in deal but also looking at their upcoming Ultra Lite 28 similar design. I was thinking of going used on a 290 but at $29,995 I would rather get a new 14 or 15 with extended warranty up to 7 years
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 09-08-2014, 03:12 PM   #9
Planostu's Avatar
Wicked, check your email you have in your profile. I sent you a reply that was a little long for the forum with some contact info on it.
Old 09-08-2014, 03:20 PM   #10
wicked1's Avatar
Thank You I will check it
roo, roof, vent
