Old 06-19-2016, 10:50 AM   #1
MrNiceGuy's Avatar
Rubber Window Gasket
The gasket around the window in our dinette slide has pulled out from the frame. I have tried to push it back into the slot which secures it a number of times. It just pulls back out when I retract the slide. Does anyone know if there is a special tool or method for setting the gasket back into the frame?
Sent from my KFASWI using Tapatalk
2015 Crusader 315RST
2011 Silverado 2500HD
MrNiceGuy is offline   Reply With Quote
Old 06-20-2016, 05:54 PM   #2
MrNiceGuy's Avatar
I was able to get the glazing bead back in place once I was able to find out exactly what it was. At this point I'll close the post.
Old 06-22-2016, 08:18 PM   #3
Platokidd's Avatar
Curious, how did you get it back in place?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 06-22-2016, 09:02 PM   #4
MrNiceGuy's Avatar
I used a credit card and slid the card between the window and the glazing. After I got the glazing back into the slot I cleaned it and used some spray lube to allow the seal to slide smoothly over window.
gas
