Old 02-19-2014, 09:00 PM   #11
rracer5's Avatar
Here's what wiring looks like for Sabres. I'm sure other brands all look this way:
I'd bet dollars to donuts that what you want doesn't actually exist.
HOLY WIRES, BATMAN !!!
I knew there was a lot but, that's more wires than I imagined.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-19-2014, 09:41 PM   #12
rracer5's Avatar
Originally Posted by gonecampin View Post
What ever happened to rv guy. Haven't seen any replys from him in a while.
Never fear. RV Guy still checks in on us once in a while. His last activity was 2/10/14.
He's a busy guy I assume since the company is doing so well.
2014 Sanibel 3250
Old 02-20-2014, 08:00 AM   #13
donzie67's Avatar
Is the fireplace in the Crusader 260RLD electric only or does it run on propane as well?
Prime Time 2014 Crusader 260RLD Touring Edition
2006 F-250 4x4 King Ranch FX4 6.0 Powerstroke Diesel
Don & Katrina + Copper the Beagle
Nights camped 2012 = 48, Nights camped 2013 = 46, Nights camped 2014 = 47, Nights camped 2015 = 49
donzie67 is offline   Reply With Quote
Old 02-20-2014, 08:04 AM   #14
another_newfie's Avatar
It will be electric.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 02-20-2014, 08:10 AM   #15
donzie67's Avatar
So if 95% of my camping is boondocking, then I would have to run it off my inverter or start my generator? If so, do you know what the DC ah draw is?
Old 02-20-2014, 08:19 AM   #16
jriddering's Avatar
So assuming fireplace is 1500 watts at 120 volts that is 12.5 amps at 120 volts or 125 amps at 12 volts. Not a good idea off batteries.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 02-20-2014, 08:23 AM   #17
donzie67's Avatar
Guess it will be nice to look at on a warm summers day. For some reason I thought it ran on propane as well. I have 300 watts of solar and 4 6 volt batteries and even with that I will not use it. Guess when I want to use it I will have to have shore power I fire up the generator. Thanks for the bad news. LOL. I guess it's better to find out now then after I'm out on the beach and want to use it.
Old 02-20-2014, 08:24 AM   #18
Maybe (RV Guy) is wiring a RV or sitting in front of a Fireplace?? Youroo!!
Old 02-20-2014, 10:21 AM   #19
If you need heat when boondocking stick to the LP furnace. The fireplace is better to stay off.
I have to wonder if the slide wear issue has caused RV guy to silent.
1 Fantastic DW
1 Amazing DD
Old 02-20-2014, 10:46 AM   #20
We took our new 325res out two weekends ago for a test run. We were in a campground with hookups. It was a little chilly at night 35-40 degrees we had the electric fireplace going and it heated the Living Room and Kitchen but the Bedroom and Bathroom were too cold so we had to run the furnace too. It is nice but......
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
