Old 05-12-2013, 04:47 PM   #1
07 ThunderRoad's Avatar
Unhappy RV Guy help, Used tank flush and flooded coach
Used the black water tank flush and noted water flowing out from under the side of the coach. Removed the panel in the basement and found the area under the steps and bathroom sprayed down with water. Used a wet vac to clean up. Traced hose from tank flush connector up the bathroom wall and than back down to the black water tank.
Why is the hose run up the inside of the bathroom wall? Dealer is talking about having to remove the wall to get to the leak in the hose. Is there another way to run this hose? After the dealer fixes the leak, how can I get to it if this happens again?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 05-12-2013, 05:18 PM   #2
Commercial Member
huntr70's Avatar
Probably has the vacuum break valve up in that wall.
Most mfg run the line up, then into a U shaped break, then back down to the tanks so they will drain into the tank instead of back washing.
I had my Wildcat do exactly what you are saying, and there was a stink bug stuck inside that break valve.....
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 05-12-2013, 05:37 PM   #3
irishrv's Avatar
Rv guy works at prime time manufacturing. According to your profile you own a coachman.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 05-12-2013, 06:15 PM   #4
This is why they used the wall. Youroo!!
Old 05-12-2013, 07:17 PM   #5
Toy-aholic
his sig. shows a new Sanibel-Primetime
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 05-12-2013, 07:29 PM   #6
bubbles's Avatar
I believe that is a type of back flow prevent valve. It probably would not be needed since the tubing is routed the way it is (up high then down to the black tank) but it will prevent backflow. It probably is a gov standard requirement. After disconnecting the water hose from the black tank rinse input there will probably be some residual water return but it will not be black water. Of course I could be completely wrong on this.
Old 05-12-2013, 07:38 PM   #7
Put your reading glasses on, sport, and try again.
The Coachman Clipper popup is for the people that think they are going to sleep in DW'S Sanibel 3600. Including those people she brought home from the hospital for me to feed and shelter the first 18 years of their life.
Old 05-12-2013, 09:42 PM   #8
irishrv's Avatar
Ok "sport". No sig with a sanibel shows up in the forest river app. So not too far fetched to think you Rv in what's in your profile.
09 GMC 2500HD D/A
Old 05-12-2013, 09:51 PM   #9
DS ADV Rider
Used the black water tank flush and noted water flowing out from under the side of the coach. .......
My Lacrosse did the same the first time we used the black tank flush. Water was running across the bedroom floor and going under the walls, and was running out from the underbelly.
Turns out the plumbing fittings behind the UDC (where the hoses and coaxs connect) were not properly tightened. After the dealer said he fixed it, it still leaked and I had to tighten the fitting even more.
Makes you wonder how testing and PDI checks don't find out manufacturing defects like this.
Bob
Lacrosse 301RLS Touring Edition
GMC Sierra SLT 2500 4X4
BMW F650GS Dakar
Suzuki DR350SE & Suzuki DR650SE
Specialized FSR XC Comp
DualSport is offline   Reply With Quote
Old 05-12-2013, 10:00 PM   #10
Denver, CO
garbonz's Avatar
I had a trailer for two years and the vac breaker went. I ripped all that out and just use a valve in the line that I shut off before I shut the hose at the spigot.
2017 Fuse 23T
Old 05-13-2013, 08:49 AM   #11
You have Signatures turned off in the App settings. Might want to turn that on.
Old 05-13-2013, 09:49 AM   #12
Commercial Member
07 Thunder - What you're describing is how we have to do it by code and the photo above is a good representation of what it will look like. The check valve will be accessible via an access and your dealer should not have to "remove a wall". If you'd like to contact Roger in our customer service group at rstickel@forestriverinc.com he will be glad to give you or your dealer assistance. We truly apologize for the loose/broken fitting and hope to get you fixed up quickly.
PTM
RV Guy is offline   Reply With Quote
Old 05-13-2013, 05:30 PM   #13
Where is the App setting? I updated my profile page. Would you mind checking to see if I got this corrected?
I'm on a lot of forums and this is the first time anyone has checked any other info on me. Thank you irishrv.
Old 05-13-2013, 09:05 PM   #14
irishrv's Avatar
Your profile looks good shows Sanibel and coachmen. The signature setting is in the forest river ipad\iphone app. It comes turned off by default. I've now turned mine on.
Thanks.
Btw my back flow valve on a previous 5th also cracked and leaked. One cause is failing to winterize the black tank flush...which I missed. I ended up just removing the valve and using some shark bite fittings on the pipe to bypass. Worked great afterward.
09 GMC 2500HD D/A
Old 07-08-2013, 08:23 AM   #15
Ccfd48's Avatar
does the flush do both front a rear tanks in 360bhs or how is the black and greys layed out when i put water into the black rinse and open rear valve nothing comes out open the front and water comes out what is the procedure on doing the rinse cycle?
Ccfd48 is offline   Reply With Quote
Old 07-17-2013, 04:52 PM   #16
irishrv's Avatar
Black tank only. No grey tank flusher.
09 GMC 2500HD D/A
