Old 05-26-2013, 11:59 AM   #11
Barry and Wayne
If this was a simple: My refrig wont' switch from electric to propane; my kitchen roof vent stopped working, the A/C is not cold enough, etc. I would agree completely that this is a dealer/warranty issue. Wayne, sorry I have to disagree about the dealer having direct communications with PT based on my experience after taking it to the dealer the first time (before the water tank incident) for some warranty work. If anything it was just the opposite. But then again, maybe that was the dealers fault.
Getting back to the issue at hand, when a fresh water tank comes undone after only two trips there is obviously a problem that needs to be addressed. Either the technician that installed the tank did a improper installation or the technique they use to mount the tank needs to be re-evaluated. The purpose of the letter was to advise them that they "may" have a problem that if not corrected "could" lead to a product liability lawsuit for PT if a full water tank was to drop out from under a trailer while traveling at highway speeds.
Once again, my letter was non-threatening. If was simply informative stating that I had a problem that "could" lead to potential liability for PT "if" this is a widespread issue and you might want to take a look at your water tank installation method. Even if it was sent directly to their liability depart, which I doubt, a letter or phone call to me acknowledging it was received and the issue was being looked at is appropriate.
Barry, you may have a point. No I didn't send it certified mail, so I have no record that it was actually received. But I did send it from my PO to the address they list on their website for correspondence "mailing address." Since I included pictures it was a large 8X11 inch mailing envelope so I would think it would have been hard to misplace/loose. Also, it has not been returned to me. Hopefully you are right and for some reason my letter never arrived. I would rather think that was the case instead of them just ignoring me. However, from reading this forum I get the impression that RV Guy pretty much reads all the posts and responds accordingly. Apparently he also doesn't think my issue is worth commenting on or for some reason didn't read my original post.
I'm going to call the dealer tomorrow to make an appointment to have them inspect the water tank, replace the torn skirt, address the dinning area light switch issue and a few other minor problems. I'll let you know how responsive PT is to addressing this issues.
Brad
usraptor is offline   Reply With Quote
Old 05-27-2013, 10:01 AM   #12
Commercial Member
Good morning,
PT has received this letter and photos. I'm very surprised that contact has not been made with our customer in this instance as the letter and photos were received and shared with several people in our various operational groups. Obviously, someone dropped the ball on following up if we've not made contact. Our Director of Customer Service was on the road visiting dealers last week so maybe that's where the "hole" is, but still that's no excuse for a week long delay in responding.
We will be on it in the AM.
I would like to offer an alternative opinion on the tank issue. Sanibel has a power tank fill - it's NOT gravity fed. Upon reviewing the photos submitted to us, the damage to the steel straps and damage to the steel angle iron is very consistent with damage caused by a fresh water tank that has been severely overfilled. This could have been done by PT during our on-line testing or at the dealership during their PDI. We do not feel there is a structural design flaw in the Sanibel.
Sorry for the delay in responding. Have a great Memorial Day.
PTM
RV Guy is offline   Reply With Quote
Old 05-27-2013, 10:17 AM   #13
That's kind of scary. I asked once before how you could tell when the tank was full and was told (unofficially) to watch for water coming out the vent. I've noted that the fill line and vent line appear to be the same size so, unless the vent was plugged, how is it possible to "severely overfill" the tank? (I want to avoid doing that myself.) It sounds like we need to keep the flow rate at a fairly low volume then?? And if that is the case, don't you think it would be prudent to put the appropriately-sized flow restrictor into the line at the factory? (You know, a metal washer with a hole in the middle.)
Old 05-27-2013, 10:52 AM   #14
Commercial Member
Monitoring the water level in your fresh tank on your Monitor Panel while filling is the recommended method for preventing an overfill situation.
Although not recommended, some people probably fill their tanks until the water comes out the vent. The problem with this method on a POWER FILL (and potentially on a gravity fed system) is that your water entering the tank is under great pressure and will not be restricted while entering the tank. The water inside the tank is not under the same amount of pressure and will not be able to vent at the same rate as it enters. Thus, while water would be discharging out the vent, if you keep putting it in at a faster rate, the tank will overfill. This doesn't even account for a situation where there might be a small restriction (clog or kink) in the vent tube.
Too often, you start doing something else, forget the water is hooked up, don't notice it coming out your vent, and your tank is overfilled. I know for a fact this has happened at dealerships during a PDI and at our own testing facilities. I also know the damage that can occur and what it looks like.
Unless there is a restricted vent, you will not overfill your tank if you turn off the water when it starts to discharge out the vent.
Again, we recommend you use your monitor panel instead of the overflow method to know when your tank is full.
PTM
Old 05-27-2013, 10:56 AM   #15
Wanna Be Camper
SaskCampers's Avatar
If it has a power fill, perhaps some sort of shutoff mechanism should be incorporated to prevent this type of incident from happening to owners who are uneducated in this type of system as most people IMO would not even think such a thing could happen. Or maybe even some type of large warning where the line is attached. If the panel uses lights like most why not just take a feed off the full indicator to shut the system down?
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 05-27-2013, 11:09 AM   #16
PTM
Thanks!
Old 05-27-2013, 10:18 PM   #17
RV Guy, thanks for the response. However, I have to respectively disagree with you that this is not a design flaw if it has happened several times, whether it's due to overfilling with the "power tank fill" or otherwise. I have to agree with TheSasks that if this is and has been an issue then some kind of automatic cut-off needs to be installed or a better tank mounting system developed so this will not happen if the tank is overfilled. Also, I'm having a hard time figuring out how you "overfill" a tank, power fill or not. The tank is only so large and can only hold so much water. While the tank is plastic it is pretty thick and I don't think it is going to "stretch" enough to allow several more gallons of water into the tank. If the tank is full the back pressure on the hose will cause the water flow into the tank to slow significantly, much as it would if you had a nozzle hooked up to it. Besides if the difference between the straps failing and not failing is only a few extra gallons of water in the tank, than PT is cutting the "safety factor" or "margin of error" way to close and needs a better mounting system. This is referred to as "Risk Management."
Irregardless, everybody knows that the monitors inside the trailers are notoriously inaccurate in measuring how full or empty a tank is. And if dry camping for a few days, every gallon can make the difference between breaking camp to refill the tank and finishing the trip without having to do a refill, especially with the small water tanks installed in the Sanibels. The "standard" method for filling a water tank has always been to fill it until it "burps" from the overflow tube. If this is no longer appropriate with the "power tank fill", then warning signs need to installed in the hookup panel along with some kind of automatic cut off and a big bold section included in the owner's manual. Personally, I think the more appropriate fix would be to use thicker straps and to through bolt the straps to the frame with case hardened bolts instead of metal screws that aren't designed for this purpose to start with. Problem solved for couple of dollars more in construction costs and no need to re-educated everybody on how to fill a water tank or PT having to invent an automatic water cut off system. Regardless of whether you try and re-educate everybody, somebody will over fill the tank, snap the connections and then drop a full 500 lb water tank on the highway while traveling at highway speeds which has the potential of causing a catastrophic accident and a lot of liability to PT. Food for thought.
Brad
Old 05-28-2013, 01:02 PM   #18
Shane Imus, from PT, called me first thing this morning and apologized for nobody getting back to me. We had a very pleasant conversation and he/they agreed to work with me to resolve the fresh water tank issue. I have an appointment this coming Monday to take the Sanibel in to the dealer. Will advise how everything went when I get it back.
Brad
Old 05-29-2013, 09:51 PM   #19
wmcclay's Avatar
I for one put a adjustable water pressure regulator in my conv center. Set at 30 psi. I do not turn the fill faucet on more than 1/4-1/2 turn and STAND there and watch it. I help a friend replace a split water tank on a Keystone product, what a mess!!!!! It was inside the unit. On a 60 gallon tank with 10 psi in overfill condition there is TONS of pressure. Surface area in square inches times 10. I to fill until it comes out the vent, I want it full. We dry camp most of the time so a few gallons are important. My tank gauge is very inaccurate. Barry give me a PM
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 06-10-2013, 12:43 PM   #20
Oldcamp1986's Avatar
Possibly the same issue
I just looked at my fresh water tank and think I have the same issue. The underbelly is sagging. I have a 2012 Sanibel 3500. Last year while traveling the country, I noticed water tripping from the vent. I did NOT fill the fresh water tank so didn't know this vent was related to the fresh water tank. It turns out the valve to switch between city and tank was put in backwards. My fresh water tank was filling on its own when set to city water use. I traveled a long way with water onboard that I did not intentionally put there. I will need to get my straps check too and would expect Prime Time to cover this as part of their warranty.
Oldcamp1986 is offline   Reply With Quote
