Old 10-19-2012, 10:42 PM   #1
sanibel 3500 scary problem
We just bought this fifth wheel brand new and we took it for our vacation in North Carolina. this is a 800 miles trip. We choose Sanibel after looking at their website and seeing the quality of construction. On my arrival at the campground, after opening the slide-out, I saw 2 bolts that were loose under the sofa and table slide-out. The nuts are rusted and I cannot tighten them but I can rotate the whole assembly. there is a gap of 1 inch before the nuts is fully tighten. We love the trailer and the inside built quality. I'm kind of disappointed when I see this. Those 2 bolts are not hidden. They are in plain sight under the slide-out. Why did those 2 bolt not taken care at the quality control check and how many are loose somewhere else ? This is a scary situation. Is the whole fifth wheel box just lying on the frame with many of these bolts not tighten at all. The customer support at Prime Time tell me to try some wd40 and try to tighten them or go to the dealer where I bought the fifth wheel. If I were on customer support, I would have said "don't move your fifth wheel and we'll send somebody check this out" or "we'll find a way to tow your trailer to the nearest dealer safely". At the last resort, I would ask the customer if he could drive his fifth wheel at the factory for a complete check-up of the unit. But NO. They said "try some wd40 and go back home to see your dealer" Is it safe to go on the road now since I know there is loose bolts holding my fifth wheel box to the frame. Do anybody else had this problem ?
ID:	20860   Click image for larger version
ID:	20861   Click image for larger version
ID:	20862   Click image for larger version
rlev is offline   Reply With Quote
Old 10-20-2012, 01:19 PM   #2
I am surprised at the response from Prime Time. We have always had very postive interactions when needing assistance. Now that it is a weekend not sure if you will get to talk to anyone in person. For what it's worth I would be calling someone to check this out before I moved it. Go on line and see if there are any dealers where you are now. If not check with the campground to see who they might suggest. The cost of having someone take a look is priceless when you consider your safety and that of others on the road.
portliz is offline   Reply With Quote
Old 10-20-2012, 01:25 PM   #3
Another suggestion. RVGuy on this forum I believe works for Prime Time. Try to PM him. He does monitor this forum and may reply. Best of luck. Let us know how it goes. I am hopeful that Prime Time will not disappoint and step up to help.
Old 10-20-2012, 04:14 PM   #4
thanks Portliz. I send a mail to RV Guy. Waiting for a reply. This forum is great.
Old 10-22-2012, 07:56 AM   #5
Good news. RV guy put me in touch with somebody at Prime Time. They send a technician at my campground to take care of the loose bolts. Good service. thanks to all of you.
Old 10-22-2012, 09:22 AM   #6
Looks like it was pulled clear thru' whatever it was supposed to hold.
Old 10-22-2012, 09:25 AM   #7
Glad to read that PP has gone into action mode.
Would like to read after it is fixed what it was supposed to hold.
Flying dutchman is offline   Reply With Quote
Old 10-22-2012, 10:16 AM   #8
ironj's Avatar
that RVguy sure is becoming well liked around here .....i too would like to know what the final prognosis from the tech is....this is not a common complaint around these parts, and hopefully it wont give us fodder for yet another thing our "BEWARE" list of things to look for on a trailer...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 10-23-2012, 11:22 PM   #9
Glad to hear that Prime Time continues to respond to customer concerns. Happy that things worked out. Love these forums.
Old 10-24-2012, 06:15 AM   #10
Commercial Member
Ironj - there were two loose carriage bolt nuts. There are hundreds of attachment points from a "box" to a frame and it's definitely good maintenance to inspect exposed nuts and bolts periodically.
PTM
RV Guy is offline   Reply With Quote
2012, 3500, 500, bolt, sanibel
