Old 07-14-2017, 09:18 PM   #1
Sanibel 3501.
Why won't any of our holding tanks read empty when they are empty ? Lowest they read is 2/3 full. Any help or suggestions will be greatly appreciated. Thanks
chris woznica is offline   Reply With Quote
Old 07-15-2017, 09:35 AM   #2
SeaDog's Avatar
they read that way because of the scum built up on the inside of the tank. Try using a tank cleaner and falling the directions carefully, then I would recommend switching to the Geo method of tank maintenance.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-24-2017, 05:18 PM   #3
rracer5's Avatar
The only guage I get any accurate reading on is the fresh water tank.....and once in a while, the grey will read accurately. But, as mentioned, due to "stuff" sticking to the probes inside the tank (which shorts them out), they light up the lights even though the liquid is no longer that high.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
sanibel
