Old 07-13-2014, 10:33 AM   #1
Sanibel 3601 air filters
Anyone know a source for these filters? We own a Sanibel 3601 and love the unit! Need to replace the ceiling mount return air filters. Can't find them.
sasnupe is offline   Reply With Quote
Old 11-28-2014, 11:08 PM   #2
I Just vacuum them out and reuse them. If they get really bad. I haven't wash them yet. But I would use soap and water, then use a disinfectant.air dry. If you let them go to long they will draw air from outside the A/C unit with water and will rain on you. But not raining outside. Just a FYI.
jimmyt11664 is offline   Reply With Quote
Old 11-29-2014, 09:26 AM   #3
Send a message via MSN to Tiggerdad
If it is the foam type like mine you can buy a large piece at Wal-Mart and cut to fit. The foam type is the same material used in window units.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 11-30-2014, 10:04 AM   #4
wmcclay's Avatar
Air filters in an RV A/C unit are important, the evaporator (part that puts the cold inside) are hard to clean. Prime Time would not have put them in if not needed, they cost money. They are like changing the oil in your TV.
I get mine from
Air Filters Inc.
8282 Warren Rd.
Houston, Texas 77040
Measure length, width and thickness, your lungs will thank you
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
