Old 08-24-2015, 08:04 AM   #21
Thanks, I am going to inspect the tow vehicle again for voltage. I am curious why RV specialist told me that it doesn't have a charge circuit on a the trailer. Seems like everyone has it. Appreciate all your help. 😊
jimmyt11664 is offline   Reply With Quote
Old 08-24-2015, 08:28 AM   #22
You will get a small charge from your truck to your fiver battery, but not nearly enough to keep up with a residential frig. Say your fridge takes 5 amps at 120 volts. That is 50 amps at 12 volts and your battery will be drained in 2-3 hours.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-24-2015, 11:26 AM   #23
We have a 2014 Cardinal with the residential fridge also. Had the same problem you have. Checked everything like everyone has said. My solution was to add 4 - 6 volt golf cart battery's. Solved our problem. I have checked the volt drop here at home with it unplugged and fridge on. In 24 hours it only dropped .4 volt. I never checked it any longer than that.
2017 Ram 3500 Laramie Longhorn
2014 Cardinal 3850
If Your Getting Passed On The Right You'r In The Wrong Lane!!!
fenderbender is offline   Reply With Quote
battery, charging, sanibel, towing
