Old 09-07-2014, 02:32 PM   #11
I'm confident they will make things right.
TMMason is offline   Reply With Quote
Old 09-07-2014, 03:57 PM   #12
vinmaker's Avatar
Wow. Sorry your unit has all those problems. Good luck working with your dealer to get it fixed.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-09-2014, 12:42 PM   #13
Platokidd's Avatar
Originally Posted by Ductwerks View Post
I have a 3600 sanibel and the bottom of my 2 big slides is ripping they used a material that is not holding up.
Here is a link for ya.
Slide out /Underside wearing
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-17-2015, 10:09 PM   #14
The fridge doors do open when traveling down the road. I installed children latches at the top of the doors at the opening end of the doors. We have not a problem with this since I have done this. I got the latches at Walmart. The slides are out of adjustment. We had our delivery dealership adjust them and made them worse. They adjusted them in the wrong direction. I know that you are frustrated. But we all to get the bugs worked out. You will love your coach. Primetime really stands behind their products. Also Rodger is good people to. Good luck.
jimmyt11664 is offline   Reply With Quote
Old 02-18-2015, 03:53 AM   #15
I hope you get all your issues sorted out.
Unfortunately mine and others experience with Primetime and Roger Stickel has been that if they can find a way to get out of their warranty obligations, they will take it.
Or at least they will use stall tactics.
Hopefully your dealer makes them fix their poor workmanship in a timely manner.
Samaka is offline   Reply With Quote
Old 02-18-2015, 08:12 AM   #16
I have a 2014 3600 and have no had any major issues not even evidence of frame issues. Most of the items I did have to where taken care of during PDI and accepting the unit. Not sure how detailed of a walk through your dealer did, but it sounds like not much of one before you took posession.
But if you just got the unit 2 weeks ago, how did you miss some of this before you drove off the lot? I know its winter and cold, but I would not have take delivery without going over the entire unit.
That being said, my experience with the warentee work has been great. Nothing has been rejected on me, and I have not had to spend any of my own money on repairs. After a season of use I started to have some of the bottom slide wrapping show wear and the dealer did a great job adressing it for the long term.
jbrostek is offline   Reply With Quote
Old 03-07-2015, 02:44 PM   #17
It is also important to have the unit level before opening the big slides
Ductwerks is online now   Reply With Quote
Old 03-15-2015, 09:12 AM   #18
Sanibels
Man after reading some of these post, I'm having second thoughts on buying a Sanibel now. I thought Sanibel's were built to a better level than I'm hearing. Better start researching other manufacture now.
Piperflyer is offline   Reply With Quote
Old 03-15-2015, 09:56 AM   #19
stallsmi's Avatar
It disturbs me how on this forum, some people blame the OP for problems existing on his unit. Whether he missed them on PDI, or they weren't readily apparent, is immaterial. The guy wanted insight and help, not comments like "how did you miss this?" I know I won't change things or people, but this should be a helpful forum. Good luck on getting your problems fixed!
stallsmi is offline   Reply With Quote
Old 03-15-2015, 10:15 AM   #20
It's a great unit once you go over eveything, so far nothing major. I meet someone in the wisconsin dells and suggested removing the wall in the basement by the stairs to access your water heater and pump. When I did the construction debris I found was shocking.
sanibel
