Old 12-15-2018, 01:34 PM   #1
debihen's Avatar
Smile Sanibel 3751 Furnace Location
Can you tell me where the furnace is located in the Sanibel 3751? Considering a 2018, and wondered if furnace is easily accessible? Thanks for input.
debihen is offline   Reply With Quote
Old 12-15-2018, 02:07 PM   #2
cavie's Avatar
start on the outside. Look for an over/under 2 hole vent. That would be the intake and exhaust for the furnace. The furnace will be at floor level inside. It will have a large vented leuver in front of it.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-15-2018, 02:45 PM   #3
X2 based on the photo's I saw on line looks like it is right behind the front slide. Probably under the stairs. I would hope there is an access panel.
Kimber45 is offline   Reply With Quote
Old 12-15-2018, 03:51 PM   #4
rracer5's Avatar
I can almost guarantee that it's under the stairs/landing under the window on the stair landing. Access it by removing the panels in the basement storage area on the curb side. Behind there you will also find the water pump as well as the water heater.
EDIT; It is in that area. Just closer to the storage bay doors & behind the water docking station.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
cat, furnace, location, sanibel
