Old 07-10-2015, 08:00 PM   #1
Sanibel 38 BQ matress size
my wife and I just put a deposit down on a Sanibel 38 BQ, and it comes with a queen mattress. The brochure states there is a king upgrade. does anyone know is this as simple as buying a king mattress and putting in in, or does the actual base of the bed need to be changed out?
thanks
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 07-10-2015, 09:14 PM   #2
jtstromsburg's Avatar
Don't know, but I'd guess new plywood base would be needed, as well as removing two side tables.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 07-19-2015, 04:18 PM   #3
rracer5's Avatar
Usually, the underbed storage would be made larger to support the larger plywood base. Yes, you would loose the side tables and 2 small shelves are added. This is normally a FACTORY ordered upgrade and usually not done by the dealer.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 09-15-2015, 10:13 PM   #4
We had them install king bed at the factory. They did not charge for the upgrade.
Fatty1 is offline   Reply With Quote
sanibel
