Old 05-30-2015, 07:51 AM   #1
Sanibel 38QB
My wife loves the floor plan. We are considering full time living. Can you please give me the good and bad of this particular unit and brand. It just came on our radar. We had been looking at the other rear bunkhouse models.
Fatty1 is offline   Reply With Quote
Old 06-04-2015, 11:19 AM   #2
rracer5's Avatar
The model you are looking at is a new line just out the past few months so, you probably won't get any specific responses. We have the first line of Sanibel's........and love it. Prime Time's customer service is second to none and they're a good solid unit.
The only difference I see between the Sanibel series and the Sanibel Traveler models is smaller grey and black tanks, no dresser in the front closet and lighter pin weights (possibly due to the lack of dresser?)
We will admit to a few minor problems, others have had some major issues but, overall, most here on this forum seem to be very happy with their choice & Prime Time.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-04-2015, 12:00 PM   #3
clr
Like rracer5 said the model is very new, so not many on the road yet for feedback. I have a 2015 3601 Sanibel and love the unit. The livability of the unit is much greater than what I was expecting. I have had several issues with my unit but PT and my dealer have quickly corrected the problems. Prime Time is great to do business with as customer relations go they even answer their email and phones in a very timely manner. You should try and send an email to Keystone or Heartland, you will lucky if you ever get any response.
clr is offline   Reply With Quote
Old 06-04-2015, 06:28 PM   #4
I have to say I have emailed Prime Time 3-4 separate times this week and they have replied within 1-2 hours each time. I'm very impressed so far. Most everything I have read about the Sanibels the owners are very happy with them. I'm going to most likely pull the trigger tomorrow and order it. Just doing some homework on hitches since I have never owned a fifth wheel.
Old 06-04-2015, 07:38 PM   #5
CWSWine's Avatar
Saw one the other day in Camp Ground and looked it over. Unique floor plan and looks really nice. He only had about a month but hasn't had any problems with it. The person that bought it ended up trading his 2500 Chevy Diesel in for Chevy 3500 since the pin weight was over 3,200 lbs when he took it to the scales. Make sure you have enough truck to except the pin weights over 3,000 lbs.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-04-2015, 08:54 PM   #6
Did he have SRW or DRW? After all the research I have done the 2500 with diesel seems to be sufficient but I do not want to buy the wrong truck. I'm buying it before I buy the camper.
Old 06-04-2015, 10:36 PM   #7
CWSWine's Avatar
He had single rear wheel. He said fully loaded it exceed the 6200 pound rear axle rating on his 2500. I have Ford F350 SRW diesel and the Website said my cargo limits was 4190 but when I got the truck the yellow sticker on the truck said 3844 max cargo. I bought 315res and the website said it had a dry pin weight 1950, i loaded the stuff I carry all time and the pin weight went to 2800 and ready to camp it hit 3090. The majority of the stuff you put in the forward storage adds to your pin weight.
Figure 20% to 25% of gross weight (not dry weight/shipping weight) will be your ping weight, probably around 22% or 23% is good figure.
The 2500 has about 16,000 pound trailer tow capacity but you run out cargo weight capacity long before you run out tow capacity.
Better off having to much truck then not enough!
Old 06-04-2015, 10:50 PM   #8
CWSWine's Avatar
I see the GMC says 2600 lbs payload but remember that you have to take off 200 for the hitch so 2400 lbs plus full tank of fuel, passengers, and misc stuff you carry in the truck so doesn't leave much for a trailer that big. Just my thoughts. That 2600lbs is a stripped down truck so you have to subtract options you put on the truck above basic truck.
Old 06-04-2015, 11:42 PM   #9
The GMC site says the payload is 3560. Am I not accounting for something properly?
Old 06-05-2015, 06:54 AM   #10
CWSWine's Avatar
GMC 2500 4 wheel drive diesel on the GMC crew cab site shows me 2626 and Standard cab (no back seat) listed at 3174 and these are stripped trucks. Options can take away between 1 and 700 lbs of cargo.
This was my 2013 2500hd that the website said 2890 but here is the real deal weight of 2475 with LTZ and Z51 options. You need to hit the Chevy/GMC dealerships and look at the door stickers on the trucks you want to buy. When I order my F350 it was 4200 lbs on the website but the door tag said max cargo of 3844 lbs and I made the dealer put in the order sheet I could refuse the truck if below 3800 lbs cargo.
sanibel
