Old 07-28-2016, 07:40 PM   #1
Sanibel 3901 tow weight capacity
Does anyone know what the tow weight is? Looking at a rear rack for generator.
mellis is offline   Reply With Quote
Old 07-28-2016, 10:37 PM   #2
grhodes50's Avatar
It would probably be best to contact PT on that......Prime Time Contact Us
Gary & Trish
2017 Nights Camped - 4
Old 07-29-2016, 04:59 AM   #3
chesbass
I'd be interested to know that as well. are you having a hitch welded on to the rear part of the frame? I would like to carry a small golf cart.
Please post it here when you find out.
Thanks Steve
chesba88 is offline   Reply With Quote
Old 07-30-2016, 05:07 AM   #4
chesbass
Exclamation
I spoke to PT regarding welding a hitch to the frame at the rear of my 3901 to carry a gulf cart and it was recommended that I NOT do it. The frame and under structures of these rigs would be compromised if I did. It was suggested that the weight that would be extended out beyond the end together with the stress from bouncing is more then could be handled and in time damage would occur. I also suppose it could void any warranty in effect. I have seen however some folks do it...GOOD LUC
Old 07-31-2016, 10:36 AM   #5
rracer5's Avatar
Check out my past post/expeience when I inquired.
Crusader Back Rack(Bike) Opinions...
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
sanibel, weight
