Old 06-10-2013, 01:48 PM   #11
Originally Posted by Oldcamp1986 View Post
I had the same problem on my 2012 Sanibel 3500. I took back to the dealer and They raised the back of the sofa. The problem now is that the whole sofa has a slight angle forward.
Easier solution is to buy one of those 3-4 inch thick foam pads and cut it to fit and lay it across the head of the bed, between the arm rests, when you use it as a bed. Then the couch isn't at an angle when you sit in it and the foam pad levels out the bed. We keep the foam pad in the storage area under the main bed or I suppose you could also put it behind the couch between the couch and the wall.
Brad
usraptor is offline   Reply With Quote
Old 06-10-2013, 04:06 PM   #12
Oldcamp1986's Avatar
Thanks for the suggestion. We did use a form mattress pad while on a big cross country trip when we first discovered the problem. I was hoping the dealership would have a better solution to minimize a step in setting up the bed. It is already cumbersome with the air mattress. I may go back to this.
Oldcamp1986 is offline   Reply With Quote
Old 11-05-2014, 09:57 AM   #13
Same Slanting Hide-a-bed Problem
I too have the same problem....Roger at Prime Time will not replace the couch....I bought a Sanibel because of the great customer reviews...I am VERY dissapointed.
luvdboyz is offline   Reply With Quote
Old 11-06-2014, 05:20 AM   #14
wmcclay's Avatar
They made our much better when it was at the factory for upper coupler repair. I will try to find out what they did. If not I will give you the email of thre contact at the factpry
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 11-06-2014, 05:23 AM   #15
wmcclay's Avatar
Do not give up yet, there are people above rodgers pay grade. JEFF RANK is the man. I have fou d him to be very helpfull and a straight shooter.
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
Old 11-06-2014, 04:35 PM   #16
BBBlue's Avatar
I too would be interested in the fix. While my unit was at Recreational Specialties for the upper flex fix, I was told that if the bed was adjusted to eliminate the angle, it would affect the siting position of the couch. I opted to leave it as is. Was thinking of getting the foam piece as discussed in the forum, but if there is an acceptable fix that would not affect the sitting geometry, I am willing to give it a shot.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 11-25-2014, 10:28 AM   #17
Has anyone actually replaced the hide a bed with a different one and what did you get. We have a 2012 Sanibel 3500
colleengb is offline   Reply With Quote
Old 11-25-2014, 02:52 PM   #18
BBBlue's Avatar
My mother in law now refuses to go camping with us due to that angle issue with the hide a bed. Could be a good thing. lol
BTCM(SW) Ret USN
2013 Sanibel 3500
Old 11-25-2014, 02:58 PM   #19
TURBS's Avatar
Lol I'm wondering why anybody would complain!
TURBS.
