Old 10-06-2017, 08:42 AM   #1
pmf
Sanibel leveling
Good morning,
We have a Sanibel 3751 with six-point leveling system but it still rocks quite a bit. I think part of if not most of is the long slide in the living/kitchen slide. I am trying to decide on a tripod for the front or X-Chocks for the wheels. If anyone has any other recommendations please let me know.
Thanks,
Pat
Pat and Debbie
Beau and Goldie co-pilots
2018 Prime Time Sanibel 3751
2017 Ram SRW 3500 Laramie Diesel
pmf is offline   Reply With Quote
Old 10-06-2017, 08:54 AM   #2
Witch Doctor's Avatar
Originally Posted by pmf View Post
Good morning,
Thanks,
Pat
IMO, tripods do not work very well, x chocks work and would help. Remember the longer you extend the system, the more rock you will have, best to use blocks under the rams to shorten the stroke
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-06-2017, 09:37 AM   #3
pmf
I'm going to order some X-Chocks today. Will keep the extension in mind next time we set up.
Thanks,
Pat
Pat and Debbie
Old 10-06-2017, 11:43 AM   #4
rracer5's Avatar
I always use lynx blocks under all my rams. I try to keep ram extension within 10 - 12 inches or less if possible. Sometimes, depending on the levelness of the site, I might have more blocks stacked under one side than the other or even front to rear. You will never get rid of ALL the bounce/rocking unless you put the rig up on cinder blocks under the frame. While that may be ok if you're going to be in the same spot for a extended period, it's a hassle if you're moving every weekend or so.
Thanks,
Pat
The X-chocks will minimize the fore & aft motion but again, not completely eliminate it.
Hydraulic levelers are pretty stiff so a tripod probably wouldn't be worth the expense. Tripods work really well on those 5'ers with electric square tubed front landing gear where there is a lot of "play" so they can slide in & out of each other which equates to movement.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
leveling, sanibel
