Old 03-20-2016, 10:55 AM   #81
Not sure what manufacturer it is. I was told these were just changed. The rear cushions are in the middle of the bed with gaps all over. I wish they still had the Lane furniture.
Raymac is offline   Reply With Quote
Old 03-21-2016, 09:15 AM   #82
Originally Posted by oldgreymayor View Post
Anyone have troubles with their furnace? The check valve on water pump must stick too, because fresh water tank over flows when hooked up to city water.
Your Anderson Water Valve may be defective as was mine. Mine did the same thing. When hooked up to city water the tank would overfill or when turned to tank fill nothing happened. Very likely your problem.
Jim
Jim.mcgallan is offline   Reply With Quote
Old 03-24-2016, 06:21 PM   #83
tlamb6463, any updates? Your experience makes me pause about buying a Sanibel!!
janegowest is offline   Reply With Quote
Old 03-24-2016, 06:37 PM   #84
Not at all. My 3601 has more storage than anything I've been in. Every Rv has some issues. When we get back to Rapid City the dealer will replace the check valve. I really like the 3601. The tv hookup in the basement is great. I put a 32 inch tv on the wall mount and watched all winter here in Mesa.
oldgreymayor is offline   Reply With Quote
Old 03-29-2017, 05:05 PM   #85
jjbonker's Avatar
Originally Posted by rracer5 View Post
I've been told that if there is a "frame flex" issue, that area is the first place it will show. It is the weakest point because the side wall structure is thinest at that point & offers minimal additional support to the frame. That......looks like definite frame issues!!
Hi, did you ever get this flex issue corrected? We have a 2015 still under two year warranty until July. I just noticed we're developing suppurations there now also.
jjbonker is offline   Reply With Quote
Old 03-29-2017, 08:51 PM   #86
rracer5's Avatar
I think you want to ask tlamb6463 if he got it taken care of. It was his issue I was addressing. I hope PT did something for him. He hasn't been on here in a year.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-23-2017, 04:21 PM   #87
Angry 2015 Sanibel
We purchased our unit in 2014. THey are beautiful, but unfortunatly, we have had to have most of the unit rebuilt over the course of the last two years. I won't go into details because they are too numerous, not to mention the sadness of such an expensive lemon.
Prime Time stood by the warranty work and extended the warranty for another 6 months pending review again when those months were up, and threw in a free TV. Tv wasn't a repair issue. . Those months were up in Feb. WHen I contacted them, I was told it would be reviewed by at least 3 people and someone would get back to me. I've contacted them a couple of times and get no response at all. Sadly the fixing goes on.
Hopefully you will have a better trailer than what we got.
LErhart is offline   Reply With Quote
Old 05-10-2017, 12:41 PM   #88
Sanibel Owners
Just purchased 2017 Sanibel 3601, absolutely love it, going this week on first
trip to NW Mississippi Lake Enid
GGOSSLER is offline   Reply With Quote
Old 05-21-2017, 06:11 AM   #89
We have just been our second weekend in our brand-new 2017 Sanabel 3601. First weekend the fireplace quit second weekend the thermostat quit working. So now no heat no air in a memorial day weekend is one week away
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
Old 05-21-2017, 01:45 PM   #90
rracer5's Avatar
What makes you think the thermostat quit working? Did it go completely blank or does it show an error code (E1,2 etc)?
Old 05-21-2017, 06:28 PM   #91
I believe it is the thermostat because in the beginning it was going on and off every couple of seconds and I did the reset of the stat and it seem to work for a little while. Then it shut down completely, No light in the thermostat and pushing any buttons does no good. Have not checked for a power loss at the thermostat but check all fuses and breakers and everything is hot.
Old 05-21-2017, 08:28 PM   #92
rracer5's Avatar
Try killing the 12v power to the thermostat by either pulling the fuse, disconnect the battery or unplugging the stat from the back (it's a modular plug). Then reconnect power and see it comes back on line.
Old 05-21-2017, 09:14 PM   #93
I will give it a try, thanks I'll let you know the results.
Old 05-27-2017, 06:24 AM   #94
Unfortunately it didn't help. I've checked fuses all are good. Hopefully turns out to be the thermostat. Will advise once repair is completed dealer is scheduled next week
Old 05-27-2017, 06:29 AM   #95
Has everybody noticed the linoleum wrinkling in the corner of the slide with the fridge. I know that's the heavy corner and whenever ver my slide comes in and then I put it back out it has a major wrinkle in it. It will go down but not completely
2017 Sanibel 3601
Old 05-27-2017, 07:14 AM   #96
Had the same problem with mine and it has been seen in other models as well. Big slides with big refrigerators. On mine, the slide roller under the frig was causing damage to the linoleum as it travelled. Placed a piece of hard rubber backed carpet on the spot and further damage was stopped. Prime Time took the camper back for repair and reset the slides and repaired damage. Was also given a fabricated protector to put under the frig roller. Very happy with repairs and slides work great. Not sure I need the extra piece but I use it.
Steve and Kim
Southern Illinois
2021 Cedar Creek 311RL
2020 F350 SRW Crew Cab
si camper is offline   Reply With Quote
Old 05-27-2017, 07:30 AM   #97
Thanks will pass on to my dealer
2017 Sanibel 3601
Old 05-27-2017, 07:04 PM   #98
What is the fabricated protector made from plastic metal
2017 Sanibel 3601
Old 05-27-2017, 07:22 PM   #99
Hard plastic. Approx 6" wide by 3' long
Sent from my XT1650 using Forest River Forums mobile app
Steve and Kim
Southern Illinois
Old 05-27-2017, 07:49 PM   #100
Thanks I assume it's not real thick because the rollers have to climb up on it. Do you stand on it in the beginning of closing the slide?
2017 Sanibel 3601
sanibel
