Old 10-23-2017, 01:49 AM   #1
Sanibel scare lights
Where are the scare lights located on a 2017 sanibel. I turn the switch on and nothing happens
JeniBean is offline   Reply With Quote
Old 10-23-2017, 02:49 AM   #2
Witch Doctor's Avatar
Just behind the cap on the left and right side, you should have a switch for each side unless they made a huge change in 2017.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-23-2017, 04:27 AM   #3
Mine is under the entry door behind the steps. One light
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
Old 10-23-2017, 06:42 AM   #4
gmcdually05's Avatar
It's only one light underneath the steps.
gmcdually05 is offline   Reply With Quote
Old 10-23-2017, 06:49 AM   #5
One more thing that light is under the exterior stairs.
Old 10-23-2017, 03:24 PM   #6
clr
On my 2015 Sanibel model 3601 the scare lights are within the cabinet with all the other light switches and the tank monitor. The top row of switches is the interior lights. If I remember correctly the next row down from the top is the outside lights. One switch on mine controls the awning lights and the light behind the outside steps. The other switches are for the scare lights on the left and right side. They do seem to change the switch location around all the time so yours may well be different.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 10-23-2017, 03:53 PM   #7
Scare lights should be on Both sides with switches for each! Lights under the Step area listed as Scare Lights seems odd,these lights are listed as Step Lights on most units! Scare lights are normally around 8" in Dia.! Youroo!!
Old 10-23-2017, 08:24 PM   #8
rracer5's Avatar
X2 I too am confused. I have both; a step light under the exterior steps which is on the same switch as the exterior door (porch) light, then I have 2 8" round clear lens "scare lights", 1 on each side of the 5er. Both of these are on 1 switch in my situation.
See below
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
light, sanibel
