Old 03-16-2015, 06:44 AM   #51
Originally Posted by Bjschil View Post
We just picked up our 2013 Sanibel from the frame flex issues. Looks awesome, Prime Time was very helpful, answered many of our questions, saw a few things that needed adjusting, lighting problem, slide repair, woozers, we were amaze and thank You PRIME TIME for a job well done. You have earned our respect in wanting and showing a terrific product out in the camping world, and when one comes back, you step up to the plate. Thank you from the Schillings in Wisconsin.
Great news. Enjoy.
Pennie / Ron
2015 Sanibel 3901
Team Wilhelm is offline   Reply With Quote
Old 03-16-2015, 06:59 AM   #52
I believe that the newer models of the Sanibel and the flex frame have been addressed and corrected. For those of you traveling to Elkhart, there is so much to see and do. You can pre-arrange a factory tour of the plants, visit the hundreds of RV dealers in the are, so much industry tied to the rv business. Unfortunately, my husband was the lucky recipient of this virus/cold/flu, so we did not spend much time, just overnight. We are only 5 hours away, and chose to pick it up. They would have delivered to our dealer, however, an early Easter celebration with extended family requires sleeping spaces for teenage nephews! Thank You, again, Prime Time. We are pleased and happy.
Bjschil is offline   Reply With Quote
Old 03-16-2015, 11:41 AM   #53
Has Prime Time stood behind all you on the warranty to fix the flex issue? Is it a permanent fix once the dealer fixes it?
Is this still an issue with the newer units?
Piperflyer is offline   Reply With Quote
Old 03-16-2015, 11:54 AM   #54
There was no bill, we owe nothing, and it appears that should this happen again, Prime Time will stand by their work. I do not anticipate a "repeat performance", nor do we know if that should happen, that they would or would not stand behind their product. What I do know is that the workmanship was superb, their communications during the fix was constant, and then, when it was all done, did some other minor repairs that we were not expecting. They have a great name, and want their product to be superior, even after two years, so our speculation is yes, they will stand behind their repairs. I encourage you to keep the line of communication open with Prime Time. I did find out that the best communication is directly with the manufacturer, and not with your RV dealer. Please keep that in mind!! Good luck, you will be happy with all the service and respect given to you. Great at Customer Service.
Old 05-16-2015, 05:16 PM   #55
My 2015 3901 which is 6 months old has the same problem.
jbaird is offline   Reply With Quote
Old 05-20-2015, 08:22 PM   #56
Recreation specialist Elkhart Indiana awesome, We had issues with our 2015 Sanibel 3601. Not for frame flex. It was for slide issue. I gave them a grocery list..Had to have the front cap replaced, it took them 14 days. But we were very pleased. Unfortunately after heading back to Texas, we had several blown tires. Goodyear paid for the damage. We upgraded to G614 J ply tires. I Installed trailer fenders to prevent damage under the body. Hopefully this will help. And hopefully we won't have another issue with tires.😕. We are going back for the Frog rally to have some more repair done, then visiting family in Michigan. Hope to see you there. 😊
jimmyt11664 is offline   Reply With Quote
Old 05-29-2015, 01:07 PM   #57
Sanibel Upper Frame Flex
Lipper welded our 2012 two times I think they got it right now. If I we in the market now I would look at buying the grand design solitude. The life stiles is another we'll build 5th wheel. By Evergreen.
Surfon is offline   Reply With Quote
Old 05-31-2015, 03:56 PM   #58
BBBlue's Avatar
What was the problem with the first fix? From what I heard, it took them a try or two to come up with the final fix that apparently is now working. At least for my unit.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is online now   Reply With Quote
Old 06-01-2015, 10:31 AM   #59
Caulk was coming out of the seams in the front of rv. Repair was front flex, welded. Second time we went to dealer in IN. They contacted Lipper, and they re-welded the front end.
Old 06-04-2015, 10:52 PM   #60
Well I spoke to soon. I hooked up to evacuate and because of this great forum, I knew what to look for. Left side is dropping about a inch. The wall near the slide is bowing. We are going to the Rally in August in Indiana. Hope we can get it repaired ASAP. Wish me luck 😭
5th wheel, frame, prime time, sanibel, wheel
