Old 05-29-2014, 09:02 AM   #1
Sanibel (Prime Time) Upper Frame Flex
We have a 2013 Sanibel we purchased August 2012. We have pulled it around 10k miles now.
I started to notice that the caulk between the bottom of the overhang and the side wall was pushing out and separating on both sides but most predominatly on the passenger side. I'm not sure when this started but I noticed the caulk coming out over a year ago.
I had the Sanibel in for warranty work in Elkhart last week and before I could ask about the caulk issue (I thought it was a routine maintenance issue and I just wanted to know how to address it) the repair shop owner told me I had an "upper Frame Flex problem that needed to be repaired. He said he has done many Sanibels in the past year and he had one in the shop he was doing at the time. He said the repair takes about 5 days to do and required the bed slide, dresser, and the front fibreglass cap to be removed.
I am still waiting on a schedule to have the repair done.
Now that I know about the issue I have watched this area when I hitch up to the truck. The bottom of the overhang actually moves up about 1/2 an inch when the weight of the RV is placed onto the truck.
Are there others out there with this problem? I also want to alert others of the problem if they don't know already.
I attached a picture below to show what to look for.
The area that moves is the area between the bottom of the decal and the trim on the bottom of the overhang.
Note that the vertical trim piece under the bedroom slide is loose. It actually pushes into the slide when the weight is put onto the truck.
2008 F-450 CC DRW
2013 3500 Sanibel
rvsunman is offline   Reply With Quote
Old 05-29-2014, 10:07 AM   #2
DDC
DDC's Avatar
You have my sympathy, I assume this will be covered by warranty, I am curious did the repair shop tell you if this was covered by a recall and has the NHTSA been notified of these defects as they are safety related and could have disastrous results. The more these types of defects get reported the better the chances are that they will get the message and build them safer.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-29-2014, 07:37 PM   #3
If your getting that much flex then theres a big problem in the frame,I have flex in mine but right now its not to bad(steel has to flex but I feel the flex should not be noticeable) you also have more miles on your unit then I do.
when you first got the unit what was happening up front(the area your having trouble with now)was it just pushing out a little putty and got worse over time?
Good luck and please let us know how this turned out for you! Keepaeyeonit
ID:	53771   Click image for larger version
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2017 3 so far
2015 57/2016 52
2014 40/2013 38
keepaeyeonit is offline   Reply With Quote
Old 05-29-2014, 10:09 PM   #4
Yes, when we first got the Sanibel the putty was pushing out. It seems to me it started gradually. I didn't realize it was a problem until I was shown the issue and then watched the area when I put it on the truck. I know it needs to be fixed but was TD by the repair place that it wasn't a safety issue. After reading stuff on the internet I'm not sure about it not being a safety issue. I just know that the king pin area moves in relation to the upper outside wall when hitched to the truck. I can't seal the area so moisture can now get in. I don't know how the upper structure is secured to the carbon steel king pin frame.
Sent from my DROID RAZR HD using Forest River Forums mobile app
2008 F-450 CC DRW
2013 3500 Sanibel
Old 06-03-2014, 08:01 PM   #5
frame issue
Hi
You must be the guy I met in a campground in Waves, North Carolina. here is my post and how prime time took care of it. Good service
good luck to you
Robert
FWguy is offline   Reply With Quote
Old 06-04-2014, 05:57 AM   #6
Mine is in for repair now
Oigan is offline   Reply With Quote
Old 06-04-2014, 05:58 AM   #7
It sounds like they have a real problem
Old 06-09-2014, 10:55 AM   #8
Prime times Sanibel 5th wheel frame flex
We purchased a 2013 3501 in nov and just love it. But recently have noticed caulk squeezing out at the molding seam on the overhang where the pin box is mounted. We took measurements both on and off the truck and found an inch of flex in the frame. Is this normal? Never noticed this flex in our previous 5er. Could this be dangerous ? Any info would be a great help
chris woznica is offline   Reply With Quote
Old 06-11-2014, 08:17 PM   #9
BBBlue's Avatar
I noticed some flexing on the drivers side of my 2013 Sanibel 3500. The sealant was pushing out and there was approximately 1/4 to 1/2 inch movement when unit was up on the hitch on the drivers side only. I brought the unit to the dealer and show them the flex. The service Mgr stated that it was normal flexing and that the tape sealant needed to be replaced, since it had been almost displaced in one small area. The unit has approx 6000 miles on it. Are other Sanibel owners seeing this slight movement when putting unit up on the hitch or are you not seeing any movement?
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is online now   Reply With Quote
Old 06-12-2014, 05:49 AM   #10
Have the service manager contact prime time! If there is a problem prime time will fix it. My sanibel started to have issues with caulk and when we traveled to texas this winter when we arrived we had a hump in the bedroom in front of the bed.
5th wheel, frame, prime time, sanibel, wheel
