Old 07-17-2015, 10:40 AM   #1
Todouble's Avatar
Schwintek slide issue??
Well I just got back from a 1500 mile trek to Maine and I know my slide before stuck out at the bottom but it seems to have gotten worse. Top side is closed fully tight and bottom is out about 3 inches or so. Does anyone have any ideas or way to adjust this? There was a lot of road construction and teeth jarring moments. Maybe it jumped track if that's possible? Slide still goes in/out fine but j worry about rain getting in. I ran it fully opened and closed many times and notice while bringing it in it pulls tight on the bottom and then releases open after I let go of the switch. Same thing when I open it up it seems to go all the way and then kinda retract back in a few inches.Click image for larger version
Name:	ImageUploadedByForest River Forums1437147564.408172.jpg
ID:	83172Click image for larger version
Name:	ImageUploadedByForest River Forums1437147592.888345.jpg
ID:	83173Click image for larger version
Name:	ImageUploadedByForest River Forums1437147634.557135.jpg
Todouble is offline   Reply With Quote
Old 07-17-2015, 05:12 PM   #2
Traveling along
Bill and Margo's Avatar
Open the slide and keep the button pressed for 2 or 3 seconds and then close again holding the button. 2 or 3 seconds. Might take a few trys but it should realign them. Good luck.
Bill and Margo
2014 Silverado 1500
2014 Tracer Air 235
Bill and Margo is offline   Reply With Quote
Old 07-17-2015, 07:32 PM   #3
Todouble's Avatar
Thanks for the reply but i've tried that. No luck. I was always told to hold the button down for an extra 2-3 seconds each time in/out anyway so it's what I've always done.
Old 07-17-2015, 07:38 PM   #4
dannyabear's Avatar
Find the controller for that slide, prob in a compartment below it. Look on you tube how to reset controller. Follow directions to see if this fixws problem.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-17-2015, 07:45 PM   #5
Todouble's Avatar
I'll give it a shot, thanks!
Old 07-27-2015, 02:32 PM   #6
I believe this is the video on re-timing the schwintek slide.
2016 Prime Time Crusader 315rst
2015 Ram 3500 4x4 C.C. dually 6.7 Cummins
Diesel Mike1 is offline   Reply With Quote
Old 07-27-2015, 06:48 PM   #7
Todouble's Avatar
Mine is out from top to bottom. This video shows it being out side to side. I'll try it but I haven't had any luck yet. It's back in storage for two more weeks until I go out again anyway. Thanks for the help though!
Old 07-27-2015, 07:25 PM   #8
dannyabear's Avatar
After looking at the pics, resetting the controller will not fix this.The motor is on top and it drives a 300 to1 gear reduction that drives a rod that goes from top to bottom, this rod has 2 gears that drive the 2 racks you see on the outside of the slide. The 2 gears are not adjustable unless 1 of them has become disingaged from the drive rod. Resetting the controller will only syn the motor on the front of the slide with the motor on the rear of the slide; It cannot do anything about top to bottom.
Danny & Darlene
Old 07-27-2015, 07:46 PM   #9
mud yapster's Avatar
Can anyone help with a solution?
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 07-27-2015, 08:53 PM   #10
Platokidd's Avatar
Might want to give the mfg. a call.
Good luck and do keep us posted.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
slide
