Old 04-14-2014, 12:28 PM   #1
Second A/C in 322RES
Has anybody installed a secondary roof a/c in their 322? Wondering if it is possible or if it is pre-wired for a second unit. Just not sure the stock 13.5K unit will handle the Kansas heat.
Chuckzul is offline   Reply With Quote
Old 04-14-2014, 01:51 PM   #2
irishrv's Avatar
Is it a 50 amp connection to the pole? If not it will not be
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 04-22-2014, 07:07 PM   #3
rracer5's Avatar
X2. If you only have a 30 amp plug for shore power than it's probably not pre-wired for the second A/C. The 30 amp converter probably couldn't run both A/C's and leave any amps to run anything else in the TT (ie; micro, 110 lamps, Tv's etc.).
To do it right, you would have to run new wire for the second A/C and upgrade your converter to 50 amps. Or, run your new A/C wiring directly to the side of the TT and through the side (using a weatherproof RV connector) and just run a separate extension cord directly to shore power just for the new A/C unit.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
