sorry, its the resident worry freak.. I was just looking at my tailights and wondering if this needs to be resealed..two years old... is this something easy to redo, or should i panic again? sorry.. if its easy can you give details on how to fix this? what to use? or are they ok? thank you
i just put alittle bit of elcheapo clear silicone around those exposed middle pieces..just for piece of mind.. i just dont want water getting behind the light and into the fiberglass... can you see i worry too much? LOL
Looks like you license plate is horizontal and if it is your light is vertical. If so, that surprises me because the retaining tab is showing and it should be on bottom so water will drain out. Mine are sealed around the fixture and I added caulk where the wires come out. Left the red lenses unsealed.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
