Old 11-30-2011, 07:36 PM   #1
Vols's Avatar
Shower question
Tracer 3150bhd. In the shower the walls are lose ( not caulked) to the tub, is this normal ? Or can / should I caulk the gap so water doesn't splash up behind there?
When we took delivery I asked and the guy said " you don't want to seal it" but could not give reason why.
Vols is offline   Reply With Quote
Old 11-30-2011, 07:46 PM   #2
Malco's Avatar
I don't know why they do it that way but our last two trailers and our current one were done that way.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 11-30-2011, 09:29 PM   #3
sfrye5853's Avatar
I was told that the space leaves area for flex and if you caulked it, it would just pull away.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 11-30-2011, 10:16 PM   #4
rracer5's Avatar
I had installed a modular shower unit in my home once and the instructions said not to chalk the bottom to allow for expansion and contraction. The shower base should have a high "lip" the the walls fit over. It should be high enough that the water should not be able to get up and over behind the wall.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
