Old 05-28-2014, 07:07 AM   #11
Originally Posted by Crusader View Post
Received a shipping box today from FR. Sent a sample of tube back to FR.
If they (F/R) are (NOT) going to replace it I would send them a (Stool Sample) in the Box! Youroo!!
Old 05-28-2014, 07:47 AM   #12
Youroo, that my friend, is halarious. What makes it, is the frustration having something like that happen, and the comment you made, puts it into perspective.
Old 05-29-2014, 05:19 PM   #13
Crusader's Avatar
The sad thing is, the manufacture will most likely send me the same junk tube to replace it.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 05-30-2014, 03:52 PM   #14
WFD
I would save myself alot of frustration and replace the hose with proper pex tubing..for sure FR will send you the same stuff, thats what they use and they will simply replace it, but there is enough history of it not being great that do yourself a favor and just replace it once. Thats why I mentioned that in an earlier post, I monkeyed around with that crap hose for a week or so till an RV mechanic suggested I replace the tubing....took just a few minutes and solved all my issues...and its a cheap fix.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-30-2014, 04:00 PM   #15
BlakeB's Avatar
That pipe is melted! I'd be very interested in seeing a longer portion of tube like this. I am in the plastic pipe business (HDPE) and that print line will tell everything about that pipe. Guarantee it wasn't for use over 100deg or so.
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 05-30-2014, 04:08 PM   #16
BlakeB's Avatar
Was this on your hot water line? If so....see below. It's ONLY for pressurized COLD water lines.
RV - Plumbing - Pressure Reinforced Hoses and Tubing (USA)
Certification Standards: IAPMO TS 25 - Reinforced Hose for Use in Recreational Vehicle Pressurized Cold Water Systems
Product Description: Reinforced PVC Hose
Model Numbers: Reinforced PVC Garden Hose: W01-2105, W01-2110
White Nylon Reinforced Flexible PVC Hose: W01-2105NSF
Listing Conditions: 1. Product must be installed and operated in strict compliance with all applicable codes, laws, and regulations having the force of law.
2. The unit must be installed, operated, and maintained in strict compliance with the manufacturers instructions.
3. If a product is produced in multiple manufacturing facilities, it must bear an identification mark unique to the facility of manufacture.
Old 05-30-2014, 04:10 PM   #17
kerrlakelover's Avatar
OK, so I have to ask the question that is burning in my brain. Other than saving pennies in cost for the manufacturer, why use that hose in the water system and not just use pex throughout? I'll be replacing my H20 heater bypass valve (ceased half open) this weekend and I have that hose in several places. There's blue hose and white hose. I've not pulled any off to measure, but isn't it the same inside diameter as the blue/red pex in the system? Not sure if anyone here can answer, but I'm just thinking out loud.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 05-30-2014, 04:14 PM   #18
BlakeB's Avatar
If my TT were out of warranty i'd be replacing it with PEX if it was bad. They won't put PEX in RV's because there are ASTM standards on all pipe and this sleeved crap is what is the ASTM standard for RV's is....
Old 05-30-2014, 04:21 PM   #19
Not true,our unit has (REAL PEX) tubing not the (Field Sprayer Hose) posted! Youroo!!
Old 05-30-2014, 04:22 PM   #20
Professional Texan
TexasBob's Avatar
My 15 month old TT is totally plumbed with PEX.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
