Old 05-30-2014, 05:15 PM   #21
BlakeB's Avatar
not sure about mine...I cant check though til I get it back. PEX may very well be spec'd in too. But that cheap crap is also and is prob less expensive
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 05-30-2014, 07:11 PM   #22
kerrlakelover's Avatar
So mine has blue, white and black so called "sprayer hose" and also red and blue pex. With that said, the way they put all this together, I'm going to have to replace a bunch of "Ts" and elbows because the pex nipples are too short to cut and reuse. This is gonna be fun.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 05-30-2014, 09:40 PM   #23
WFD
I would just be concerned about replacing the white water hose, the somewhat braided Valtera stuff...don't think you need to be concerned about the red and blue tubing.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-31-2014, 08:50 PM   #24
Not trying to hijack this thread, but I spent all afternoon replacing my ceased water heater bypass valve, 3 "Ts", 3 elbows and several inches of pex as I had to construct and replace everything within a few inches of the valve. Forest River sure did no favors for anyone having to replace ANYTHING behind the docking station on my Sandpiper 345RET...and I'm guessing other brands and models are designed and put together this way.
In any case, I got everything I needed at Lowes and used the pinch/cinch clamps. I bit the bullet and bought the Apollo one hand ratcheting clamp tool which was worth every penny of the $60 I paid for it. Good news is that I had no leaks when I was finished.
After all this, I still can't figure out the logic behind using that sprayer type hose along with pex. Pex has to be less expensive than the hose. I just don't get it.
"Old water skier"
Old 05-31-2014, 09:24 PM   #25
irishrv's Avatar
I know they use flex hose to stop water pump from vibrating rigid pipe to quiet them down.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 06-30-2014, 02:52 PM   #26
Crusader's Avatar
Originally Posted by Crusader View Post
Received a shipping box today from FR. Sent a sample of tube back to FR.
Still no reply from the supplier regarding supply line …… Obviously they don’t care…..
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 07-01-2014, 10:55 AM   #27
rracer5's Avatar
X2 My $38 pinch clamp tool was well worth the money. Only had to use it twice in the last 3 years but, sure was worth it. Made easy leak free repairs.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-01-2014, 11:03 AM   #28
Crusader's Avatar
Rracer5 …….. Nothing worse than a water leak in an R.V.. It will turn an R.V. into junk quickly !!
Old 07-01-2014, 11:10 AM   #29
rracer5's Avatar
For sure!!!
2014 Sanibel 3250
