Old 10-03-2016, 12:34 AM   #1
Slide adjustments??
The bottom of our slideout sticks out about 1.5 inches and the top is tight and flush with the wall. Doesn't seem to be causing any problems inside and nothing inside is blocking it from coming in further. It just doesn't seem to be as aerodynamic as it should be?? Anyone know of an adjustment to bring it in a little more? - Thanks
ID:	122025   Click image for larger version
2017 Crusader 338RST 5'er
2013 F-250 6.7, AirLift 5000
Tim-n-Sandra & Chloe
tshelley is offline   Reply With Quote
Old 10-03-2016, 12:45 AM   #2
Iggy's Avatar
The rubber seal looks reasonable on the bottom but it looks like that plastic below needs to be checked and re-secure.
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 10-03-2016, 07:43 AM   #3
Justice12t's Avatar
Unfortunately no I do not know of any adjustments that I would recommend doing at home.
I have an appointment for my Crusader next week for a few odds n ends warranty work, one of them being adjusting the slides. After a year of use they just need to be tweaked a little. Similar to yours.
As for that plastic piece, had the same issue with it sticking out and making the slide and overall appeal look like something was wrong. I just took a few of the screws out around that area and carefully cut a notch in the plastic until it laid flat. Mine was hitting the trim piece that came down on the outside of the slide. Looks much better now.
Good luck...
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 10-12-2016, 09:52 PM   #4
Mine looks the same. I think it's just the fender skirt not a slide adjustment. My slide works well otherwise. I wouldn't mess with the slide itself to make the skirt line up.
2003 Duramax
2017 Crusader 315
1995 Ebbtide 150 Horse Johnson (etc)
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 11-08-2016, 12:47 AM   #5
Coincidence would have it I noticed the exact same thing on my 2016 295 rsk today. Looks like I need to carefully cut a notch to get it to lay flat so that both trim pieces are flush with each other
5ERSTEVE is offline   Reply With Quote
slide
