Old 05-15-2018, 09:08 PM   #1
Slide bracket digging into the tire?
I was inspecting my trailer today and noticed one of my tires has a line cut into the tread. The line goes all the way around the tire. I pulled the slide in and saw that a bracket on the slide was about a inch above the tire. The tire is elevated slightly from uneven ground. Anyone seen anything like this before or have any suggestions for a fix? It's a crusader 315rst if that matters.
Any help is greatly appreaciated!Click image for larger version
ID:	172037Click image for larger version
ID:	172038Click image for larger version
ID:	172042Click image for larger version
ironape2 is offline   Reply With Quote
Old 05-15-2018, 09:45 PM   #2
Gravity challenged
Bob_Loblaw's Avatar
Not sure what year model you have but we had the same issue with our 2017 OKBS with the torsion axles.
Our dealer contacted Forest River and found out there was a known issue with slide bracket clearance. We had 2" spacers installed free of charge to fix the issue.
https://dealers.forestriverinc.com/d...lerCentral.pdf
Jim & Susan
2017 Flagstaff 832OKBS - Days camped 2019: 4
2013 Silverado 2500HD LTZ Duramax
Try to learn something about everything and everything about something. - Thomas Henry Huxley
Bob_Loblaw is offline   Reply With Quote
Old 05-21-2018, 12:36 PM   #3
Crusader 315 Tire Size upgrade problems.
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 05-21-2018, 03:39 PM   #4
Wow. Thank you for that information. That's the exact issue I have. Same trailer. Going to give forest river a call and see what they can do.
Old 05-22-2018, 12:30 PM   #5
Good luck, I was told not covered. I just crawled under there and used an air dremel and trimmed it off. And I travel with that slide open about an inch or so and have not had any problems.
Old 05-22-2018, 02:06 PM   #6
My issue was different then your issue. Johnruff linked another thread in your thread that is my exact issue for the crusader 315rst (crappy bracket design) Last 6 of my vin is part of the recall so I am hopeful that they will resolve it. I also trimmed that corner down in the interim and if they don't resolve it I'll go the "correct track" route and lift it.
slide, tire
