Old 10-06-2014, 09:38 AM   #1
Slide out breaking bench loose
We have a 27BBS Avenger and it has a problem. When the slideout is retracted and the last foot or so comes in, the slide raises up. The dining table bench is attached to the floor and wall of the slide. The back of the bench pulls away from the wall of the slide and thus pulls out the screws from the wall. When the slide is extended it comes back together. Do other slides raise up when retracted as this one does?
EYEMAN is offline   Reply With Quote
Old 10-06-2014, 12:13 PM   #2
jevanb's Avatar
Mind does
from my S4 mini
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 10-06-2014, 12:34 PM   #3
Platokidd's Avatar
Do other slides raise up when retracted as this one does? Mine too.
What I think could be happening here is the floor in your slide flexes or bows down from the weight of couch and the table area. Thus pulling the bench away from the walls until the slide is in all way. Think you could be better off not having them screwed to the walls.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 10-06-2014, 01:27 PM   #4
jevanb's Avatar
I completely removed my table from the coach so this is not a issue anymore..
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 10-06-2014, 06:11 PM   #5
Actually, the seperation from the wall takes place when the slide is in. I did as you suggested and took all the screws from the back. The back cushion is attached serperately to the wall with velcro, so it stays in place and is ok. Thanks for the info!!!
slide, slide out
