Old 04-12-2013, 03:24 PM   #1
Slide Out cable tension adjustment
After reading the manual on how to adjust the slide out cable tension on my 2012 Tracer 230FBS, I can't figure out how to access the adjustment screws. Do you have to remove the slide out interior trim? and if so, how are they attached? I wouldn't want to damage the trim. The ones on my camper have approx. 2 inches of movement, both top and bottoms, manual states 1 inch.
CamperJim is offline   Reply With Quote
Old 04-15-2013, 10:49 PM   #2
Platokidd's Avatar
HELLO Camper Jim
I have a 2013 tracer 2670bhs. Have the same issue with my cables. What ever did you do to your slide?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 04-16-2013, 05:10 AM   #3
sail2liv's Avatar
Not sure how your slides are, but my wardrobe slide has everything visible and easy to get to when slide is in.....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 04-16-2013, 03:35 PM   #4
I did resolve my issue by carfully removing the top valences (they are only tacked on with brads/staples), after which the adjustments at the cables are easily reached. Follow the instructions on the slideout manual for proper adjustment.
Reinstall the valences using brads with an pneumatic gun is easiest.
Old 04-28-2013, 10:41 AM   #5
I am just buying a 2014 Tracer 230FBS So I find you comments very interesting, thanks for posting thm
Careless is offline   Reply With Quote
