Old 08-04-2014, 12:25 PM   #11
DS ADV Rider
Really glad to hear your slideout working again. There is a plug-in electrical connector right beside the motor that may be loose but doubt if a bang on the wall would fix it - more likely the opposite, it would fall out. Perhaps the gearbox was "jammed" (mine was seized, I think, from water ingress during winter storage when Ontario had the worst winter in recent history) and the thump freed it. Have the dealer check for signs of rusting around the motor gearbox.
I should clarify, I really like my Lacrosse and have had new trailers before and none are trouble-free - it's just the nature of the industry. They are very light on manufacturing documentation and it seems too much is left up to the individual building the trailer. However, once the initial bugs are out, I've usually had a good experience.
Bob
DualSport is offline   Reply With Quote
Old 08-19-2014, 04:26 AM   #12
Mister's Avatar
Thanks to all who posted info in this thread. I've got a Tracer with a kitchen slide that's not retracting snugly. The lower edge is staying out about an inch. I've got service scheduled and even the tech said over the phone the motor likely at the end of its life and needs replaced. That said I'm braving a trip before the service call. Maybe not the smartest move but with this info I feel I can make a valiant effort at making it home should the worst occur.
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
Mister is offline   Reply With Quote
Old 08-19-2014, 04:41 AM   #13
B and B's Avatar
Originally Posted by shooterguy71 View Post
I got my slide out to go "out" yesterday. All I did was bang my fist against the wall near the motor. I'm not sure if I have a short or something going on in the motor. I will need to get it checked out when I get back to Georgia.
Thanks for all the comments and assistance.
Sound like the moulded barnes is bad, had this happen twice. The femalconenctor has rubber flashing from the moulding process inside. Cleaned the rubber out with a drill bit used as a scrapper. Worked fine after. I did this after the harness was replaced, new one was still bad. Also treated the connector to de-oxit also known as Cramaleon. A contact cleaner that stays put.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
slide, slide out
