Old 07-18-2014, 05:09 PM   #341
The_Rhino's Avatar
LynnDiesel,
Is there a reason you chose the 3" wide Slick Strips vs. the 12" wide product made by ePlastics?
Your mod looks like the best option for me. Therefore I am getting ready to do this MOD myself & was trying to decide between ordering the 3" wide roll & the 12" wide (which can be ordered by the foot).
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2018-25
2017-31; 2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 07-18-2014, 11:09 PM   #342
The Rhino,
I went with the 3" wide x 50 ft roll because I felt this size would be easier to handle, place more accurately and get the air pockets out. The seams are tight and barely noticeable. The price per square foot is about the same. I cut 28" long pieces for the 24" deep sofa/refrig slideout and will cut 40" long pieces on the 36" dining slideout. I used a complete 50 ft roll on each slideout. The surface must be clean and dry. I trimmed the corners of each strip at a 1/8" 45 degree snip, before removing the paper back. I used a 2.5" wide metal paint scraper (pull, do not push) to apply the final pressure to secure the strips. I also caulked the sides of the slideout wall from the metal trim to the edge of the outer strip with black silicone to prevent water from possibly getting under the strip. Good luck and let us know how it performs for you.
2003 F250 7.3 PS CC
2014 Crusader 285RET
LynnDiesel is offline   Reply With Quote
Old 07-24-2014, 08:53 PM   #343
Texas
My 2013 - 295RST - has the same issue on the kitchen slide. Dealer is trying to get an approval to apply tape sealant 1st, then some type of a thin and hard strip over the tape so the guides on the floor would only contact the hard strips.. Will keep you posted.
830hvacman is offline   Reply With Quote
Old 07-24-2014, 10:05 PM   #344
Platokidd's Avatar
I use slide slickers inside,works great with the plastic wear strips so far.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 07-25-2014, 07:32 AM   #345
zs325RES's Avatar
I'm not waiting for PrimeTime to offer any fix, plus my rig is out of warranty now anyway.
The fix I did on my atrium slide has worked out so well (page 10), I did the same on my kitchen slide this week. The only difference was that I raised the room with a jack to get the strip between the rub strip and floor so there is no 'transition' when the room moves in or out. The edges are where the room weight is primarily supported, as evidenced by the pattern of wear on most rigs here. I caught mine before the darco was compromised much and used some sealant between the floor and strip to help keep water out.
It didn't cost me a thing because I had some stuff lying around, and it was not that difficult to do, so Job Done.
I'm really surprised that PrimeTime (others too) let a design like this go to production. Most other things seem to have been thought out better.
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax
Curt Q20
zs325RES is offline   Reply With Quote
Old 07-25-2014, 01:22 PM   #346
Platokidd's Avatar
zs325RES, did you take any pics of jacking the slide? Could you explain more about how you went about jacking the slide?
Seasonal
Old 07-25-2014, 02:20 PM   #347
zs325RES's Avatar
Sorry no pics, but I used my floor jack (typical). Knowing the support for the room is on the ends by the front and rear walls, I use a ~12" long 2x3 along the bottom side of the floor along the edge under the walls and lifted using another 2x2 board between the jack and the 2x3, just enough (~1/2") for the floor to clear the rub strips. Simple really.
I hope this paints the picture.
Curt Q20
Old 07-27-2014, 04:43 PM   #348
Just completed the dining slideout with Slick Strips from elastics.com. I used the 1/32" thick x 3" wide with pressure sensitive adhesive. I put 12" wide at each end and one 12" wide section in the middle. Jacked up the slide 3/4" and used 40" long strips since the slide travels 36". Very smooth operation. Once you press the strips on with pressure, they do not come off.
2003 F250 7.3 PS CC
Old 08-07-2014, 01:16 AM   #349
Texas
Well, so much for it still being in warranty, Purchased it new in April 2013, and now (Aug 2014) Out of Warranty....
Old 08-07-2014, 06:01 AM   #350
Platokidd's Avatar
Did you call pt ?
Seasonal
Old 08-07-2014, 05:02 PM   #351
Send a message via MSN to Tiggerdad
Please tell us if you called Prime Time.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 08-07-2014, 07:10 PM   #352
I called PT many times and insisted they cover the bottom of the slideouts with something more durable. After weeks of excuses, they would only authorize the dealer to cover the torn fabric with Darco tape. This proceeded to show signs of tearing only after about 5 cycles on the slideout. I immediately bought the Slick Strips from eplastics.com and fixed it permanently. If you let this go too long, moisture will get to the wooden floor and cause bigger problems. There are about 4 good solutions in this forum.
Everyone should still call PT and let them know how you feel. Only a class action lawsuit will get them to do the right thing.
Good Luck!!!
2003 F250 7.3 PS CC
Old 08-08-2014, 12:33 PM   #353
Ksilvi's Avatar
This is a known issue that my 2014 295rst also has. It's a defect in manufacturing and prime time knows it. I would not be concerned that you are a few months past your warranty. The problem didn't just start after your warranty ran out. It existed from the time you bought the unit and again, prime time is aware of the issue on the 295rst kitchen slides.
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
Ksilvi is offline   Reply With Quote
Old 08-08-2014, 12:42 PM   #354
Platokidd's Avatar
Good Luck!!!
That darco crap will last for a few cycles of the slide
I cant understand why a top notch company like Primetime doesn't make this right! They sent me strips that my dealer installed. So far so good
Seasonal
Old 08-08-2014, 12:47 PM   #355
Platokidd's Avatar
Originally Posted by another_newfie View Post
My rig is scheduled to go back to PT this week and this issue is one of the ones on the list. I wonder what they will do about it.
So how did pt deal with this issue on your unit?
Seasonal
Old 08-08-2014, 02:04 PM   #356
Wouldn't be too sure about being in warranty. This thread goes back one year and Prime Time has said NOTHING about repairs or warranty. Only apply more tape that has already failed.
Old 08-08-2014, 07:50 PM   #357
There may be a wear strip under the slide as opposed to rollers. My slide chattered when I opened or closed it. Manufacturer's rep suggested I use a product called Zep 45 on the underside of the floor. It is a silicone based product used in the food industry and is touted to be one of the few lubricants that actually work on this material. Other silicone products may make it worse.
Hope this helps.
Ron
Ron C is offline   Reply With Quote
Old 08-26-2014, 08:30 PM   #358
Thumbs down
After following this story for a year now I have decided not to buy a Crusader. I feel Primetime has not done enough to solve this problem. When you are paying $50,000 plus and they have not solved this problem it turned me away. There seems to be to many frustrated owners having this problem. I looked at the Crusaders and I liked them and looked at many of them. Always looking under the slides and along the bottom edges. We just didn't feel good about buying one and then having this issue. Where has RV GUY gone? He use to be on this website daily.
mb2011 is offline   Reply With Quote
Old 08-26-2014, 08:53 PM   #359
Platokidd's Avatar
Enjoy your new Grand Design Reflection unit! Ya know you can still be a member here on the forum
Seasonal
Old 08-26-2014, 09:09 PM   #360
Thanks , I will continue to be a member. I learned the more you read the more you will learn. Good and bad!
slide, slide out
