Old 02-21-2014, 11:41 AM   #201
Send a message via MSN to Tiggerdad
Don't understand the Darco tape. Anyone have a picture of what it looks .ike on the slide?
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 02-21-2014, 11:46 AM   #202
Platokidd's Avatar
I have pics on my profile page but they are from last summer.
You can see it on end... it had just started orange pealing then
http://www.forestriverforums.com/for...cture8538.html
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-21-2014, 11:52 AM   #203
Thanks Plato-I don't have this tape on my slide.
Old 02-21-2014, 11:54 AM   #204
Platokidd's Avatar
Dealer added it to cover up the wear..
nights of camping
Seasonal
Old 02-21-2014, 12:05 PM   #205
Platokidd's Avatar
Originally Posted by another_newfie View Post
The same thing happened to my slide platokidd. Exactly the same thing. On our Florida trip we hauled in extremely heavy rain and I had water on the floor inside the unit. I am going to closely check the slide today when I go by our storage lot to prep for a winter camping trip tomorrow.
I had Shane send me a roll of darco tape and I applied it myself. So far so good, but I will keep a very close eye on it. Should any problems continue I'll be heading to the factory.
They did my fix adjustment and 1/2 round wiper re-install when I had it winterized. Did not add more tape then. So will see this spring when I use it. I have no reason to think the wear issue is fixed at this time. Dealer took pics and talked to primetime. May have even sent them pics I cant remember right now. PT replied normal wear.
nights of camping
Seasonal
Old 02-22-2014, 05:01 AM   #206
07 ThunderRoad's Avatar
Who is Shane and how do I get my hands on a roll of this Darco tape?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 02-22-2014, 06:19 AM   #207
Platokidd's Avatar
Most dealers have the tape in stock.
https://dealers.forestriverinc.com/D...nformation.pdf
Carl
nights of camping
Seasonal
Old 02-22-2014, 07:23 AM   #208
Witch Doctor's Avatar
Carl
I still do not understand why they use the tape, Rockwood and Flagstaff line uses plastic material for the edges? Do you have rollers or a neo- prime 6" bar that it travels over? It's about 4" wide and about 1" going up the side with a strip seal on the outside. I can't see how tape can hold up. I would order the strips from FR and install them. They just staple them to the bottom. It baffles me that they can't find you guy's a solution to your problem...
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 02-22-2014, 07:41 AM   #209
Plain Old Member
Our Silverback has the darco under 3 of the slides. Before taking delivery, I asked about the plastic glides that go under each end of the slide. Come to find out they stocked them due to a Lot of requests, and problems mentioned in this thread. Mine weren't really showing any wear since it was new, but dealer charged it to FR warranty and installed them on all of the slides. They have the same problem on everything from the entry level to a Mobile Suites. I wish manf would at a minimum put filon or something under the slides. Tiffin uses a fiberglass under there's and it works well . Sunny Brook (the older good ones) used some sort of fiberglass like stuff under there's, and never a problem.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 02-22-2014, 10:22 AM   #210
Platokidd's Avatar
x2 bigjohn.............
I still do not understand why they use the tape, Rockwood and Flagstaff line uses plastic material for the edges? X2
No rollers on either of the 2 superslides. There is a plastic bar threshold or plastic strip running the width of the slide. The slide is dragged across this bar. I call it a frictional slide-out.
It dont hold up.
Thats the plan, when at the chi town show I was looking for the kind I wanted. People must have thought I was crazy looking at the bottom of the slide outs there.
Most units that I seen there that use this underside do have plastic wear strips! There are a couple of other brands that dont use it but most did or had something better/else on the bottom.
This method of attaching the strip to the slide out was 1 of prime times concerns. Staples would pull out and do damage or 2 the holes from the staples would allow a entry for moister to the laminated bottom or wood depending on which slide they were installed on. The flooring inside the unit could get damage from the wear strips. Installation of said strips would void that part of my warranty.
Your baffled how do you think I feel
At this time PT does not think my wear is a problem. They called it normal wear. I have a different opinion! This tape method is like having to check the caulk on your unit and take the action needed.
I said before and I will say it again , The folks at PT have been great! Shane and the rvguy have been awsum! All my other issues they take care of with my dealer no problems, just not this one!!! They make IMO some of the best units on the market. DW2b and I looked at the show if we were buying again...we love our lacrosse better then most 90% of t he stuff at the show in our $$$$$ range!
But PT slide outs on some units IMO needs improvement. There problems waiting to happen!At least mine is.
I think I have been fair and accurate in this assessment / post.
Sorry for the rant...Im okay now............
nights of camping
Seasonal
slide, slide out
