Old 04-19-2014, 11:53 PM   #261
I have the Darco tape and the 2 main slides are showing wear near the outer edges. On the 12 ft slide, it is worn to the wood floor. Called Primetime and they acted dumb, like no one had ever reported this problem. I was told I had to bring the RV to the dealer before they would determine how it can be corrected. The dealer is now waiting on instructions. I suggested to the dealer a product called Slick Strips (UHMW polyethylene) sold by elastics.com and McMaster Carr. This is a self adhesive plastic sheet designed for sliding. When I hear from the dealer, I will post the results. While waiting to see the service rep, I looked at a Crusader on the showroom and it will soon have torn Darco tape. PM has not yet changed the design. I believe they are hoping most customers do not see this problem until the warrantee is expired.
2003 F250 7.3 PS CC
2014 Crusader 285RET
LynnDiesel is offline   Reply With Quote
Old 04-20-2014, 12:52 AM   #262
Thanks for posting this... the Slick Strips might be a great solution. Please keep us posted.
2014 CC 34RLSA
2013 RAM 3500 Laramie CC SB 4x4 CTD
sidney is offline   Reply With Quote
Old 04-20-2014, 07:44 AM   #263
Platokidd's Avatar
I still think this is the better answer .Click image for larger version
Name:	hard plastic wear strip on slide out bottom.jpg
It also wraps around the corner of the slide protecting the ends.
Note from post 28:
part number 10F009458 slide out repair panels.
. I talked to timberview rv.
Ed, told me the way forest river wraps the ends of the side with fabric the wood rots out.This part wraps around the side to protect that from happening.
I went to a dealer the other day, so I just have to look under the slides of the units in the showroom. Check this out, new Crusader unit with duck tape on a bottom of the slide. Hmm whats that covering up???
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 04-20-2014, 12:02 PM   #264
Witch Doctor's Avatar
Originally Posted by Platokidd View Post
I still think this is the better answer .Attachment 50354
Note from post 28:
That looks and sounds like what Rockwood uses. If you look at the picture you can see where it is being dragged over the bar or what ever they are using. That's what ripping the edge. The only difference on Rockwood is that the underslide is painted or waterproofed with no material but that plastic piece go's from the 45 degree inside to the end and also wraps up 1'' on the side. I have broke 2 in 2 years, same one each time. Could be the weight that side has a stove and refer on it on my model in that corner.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-20-2014, 12:10 PM   #265
Why not install metal wear strips at the wear points?
Old 04-20-2014, 12:27 PM   #266
Platokidd's Avatar
I have seen what rockwood uses and Im not impressed.
Seen some of the plastic strips that are so thin that I dont see how they can last. Also seen some beefy strips that look like they can hold up better.
Like I have posted before, my wear is about 3" to 5" wide on the ends mostly.
My slide has no rollers or sharp objects rubbing on the slide. Just a fabric sandwich between a wear bar and wood with a superslide dragging across it.
I've been patient waiting for a real fix from primetime. Im still under warranty (few weeks left) and don't want to void that out. But this has to get addressed one way or another.
nights of camping
Seasonal
Old 04-20-2014, 12:36 PM   #267
Note from post 28:
10F009458 is this a Forest River part#?
How are they attached and can they be installed without removing the slide from the trailer?
2014 CC 34RLSA
Old 04-20-2014, 01:40 PM   #268
Platokidd's Avatar
is this a Forest River part#? Hmm think so
Ed told me they use gorilla tape or staples. Not sure if thats the best way to go for every unit.
Sounds like some here have had there wear probs fix with adjustments / screws removed and tape. Or they just dont want to say. Either way its not working on mine.
My tape is wearing / fraying or what I call orange pealing. My slide has been adjusted ...I lost count of how many times. Adding more tape is just better then a stick in my eye. Thus I keep a roll of darco tape in my unit for when needed.
If I sound irritated with this whole slide wear repair process or lack of it thats coz I am. Sometimes I feel like I've been left holding the bag.
This will have to be addressed just like caulking and other pm's. Its not a major major issue but it does need to be addressed with a real fix. Left unchecked it will lead to bigger problems.
OC with your engineering talents and workmanship Im sure this would have been fix long long ago.
Sorry for the rant!
nights of camping
Seasonal
Old 04-21-2014, 04:01 PM   #269
I have sprayed the underneath and edges of the slide facing to the front and rear using "Flex Seal." It stopped the shower leaks, will see how it does on this problem.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 04-21-2014, 07:33 PM   #270
Todouble's Avatar
Name:	ImageUploadedByForest River Forums1398126725.783776.jpg
ID:	50626Click image for larger version
Name:	ImageUploadedByForest River Forums1398126744.167512.jpg
ID:	50627Click image for larger version
Name:	ImageUploadedByForest River Forums1398126759.837107.jpg
It does look like I have some darco wrapped edge on the one slide but no signs of wearing. Main floor bottom feels like a hard thin plastic sheeting.
Todouble is offline   Reply With Quote
slide, slide out
