Old 06-03-2014, 10:46 AM   #321
another_newfie's Avatar
Is that solution not rubbing into the carpet and/or lino in the kitchen?
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 06-03-2014, 02:28 PM   #322
Irishrv,keep us posted on that fix. If you look at post#89 thats what I was going to do with mine if the fabric gets any worse(only slight scuffing for now) on our unit,how thick are they? I was going to use 3/32 materiel! Thanks Keepaeyeonit
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2017 3 so far
2015 57/2016 52
2014 40/2013 38
keepaeyeonit is offline   Reply With Quote
Old 06-03-2014, 03:41 PM   #323
Platokidd's Avatar
Ultra High Molecular Weight (UHMW) Polyethylene
irishrv
We use this stuff at work and its real tough! I had thought about this as a option as well but hesitated in doing so. I came so close to using this stuff! Here at work , it does wear some but so does everything else around it.
Ultra High Molecular Weight (UHMW) Polyethylene sheet has exceptionally high abrasion and impact resistance properties. It will outwear all other materials, including metals, nylons, urethanes, and fluoroplastics. In corrosion resistance, it has the same qualities of other polyethylenes. The working temp range is from -60 to 200 deg F. Because it resists wear, friction and corrosion, it cuts maintenance costs, energy consumption, and extends equipment life. Its properties include: low coefficient of friction, self-lubrication, non-adherent surface, FDA and USDA concurrence for contact with foods, drugs, etc. Use mechanical fasteners in construction.
My only concern with the uhmw is that it may be tougher then the wear bar???. I would hone/chamfer the corners on the uhmw and keep a close eye on things. Like screw heads, seals and wear bar abrasion.
Do keep us posted please on how it works out.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-03-2014, 05:02 PM   #324
irishrv's Avatar
Tech said he has applied this fix on many brands and never a comeback. No contact with flooring or carpet but he did adjust the slides. Apparently the lippert factory wear bar for the slide is made of the same material. Found it on line at lippert store.
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 06-03-2014, 05:08 PM   #325
irishrv's Avatar
http://store.lci1.com/uhmw-wear-bar--10-p1474.aspx
09 GMC 2500HD D/A
Old 06-05-2014, 08:12 PM   #326
irishrv,
My Crusader is in the shop and PT will not alter the design to fix the problem. I will likely do the same mod after they repair the Darco tape. What thickness is the UHMW plastic? I was thinking 3/16" will work and using glue or lock-tite on the screwed to prevent them from backing out. I was also considering covering the entire bottom; a little pricey, but maybe worth the expense. elastics.com sells the UHMW and a self adhesive thin version called Slick Strips.
Thanks for the info and the pics.
2003 F250 7.3 PS CC
2014 Crusader 285RET
LynnDiesel is offline   Reply With Quote
Old 06-05-2014, 09:42 PM   #327
irishrv's Avatar
I'm not sure about thickness. I'd guess 3/16. I'm not advising anyone do this as I wouldn't have because of the slide adjustment involved. The tech had both slides out for the install. I'm saying my dealer and a VERY SMART tech made this work for me.
09 GMC 2500HD D/A
Old 06-12-2014, 05:26 PM   #328
Platokidd's Avatar
Originally Posted by Platokidd View Post
Only a item number.
90m18891a
I received my 2nd set of strips today. They look the same as the 1st set but they have a different item number. 10F16032A
At this point I don't see any difference..yet anyway. Im going camping this weekend so I will look closer then.
nights of camping
Seasonal
Old 07-08-2014, 07:56 AM   #329
Platokidd's Avatar
Just wondering how is everyone else doing with there slide wear remedy / issue??
The strips on my unit seem to be working well so far.
nights of camping
Seasonal
Old 07-08-2014, 08:19 AM   #330
irishrv's Avatar
Uhmw working well.
2014 295rst champ te
2009 2500hd GMC d/a
09 GMC 2500HD D/A
slide, slide out
